Another I/O Option - Serial controlled I/O Kit to build...
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
SifuDean
Post by SifuDean »
Hi Guys,
I have found a solution to my other I/O requirement and it is a very nice solution.
It can be found at www.ozitronics.com
It has a user document in PDF at http://www.ozitronics.com/docs/k108v2.pdf
Basically it is a Serially controlled unit with a very basic command interface and enough Inputs and Outputs to do everthing that I think is needed.
As it is a kit you build it yourself and all we would need to do is add the serial commands to ZM through a new Script and configuration page / tab for external I/O.
I will be using this unit for a mix of home automation and alarm monitoring with ZM once I get it in my hands.
What do you think?
Regards,
Deano
jameswilson
Post by jameswilson »
sounds good
