Hello All,
Ive set up a single Camera in " Record Mode" it generates a new event ever 7 mins or so. I also set up a Filter to delete events older than "15 mins " just to test out the Auto delete functionality of ZM. I have gone through the user guide and set the filter up accordingly.
I have also attached my event filter settings.
I cannot for the life of me figure out what i am doing wrong, Any help with this would be greatly appretiated.
Filter Does Not Delete Automatically
Re: Filter Does Not Delete Automatically
Have you tried executing the filter manually?
I think ZoneMinder 1.32.x needs restarting to get the filters to run in the background (my 1.32.3 did).
Hello Kitkat,
thank you for your reply. I have tried executing the filter manually and it works fine. Its just that the auto funtion does not work.
I will try to restart the system and let you know if the issue persists or has been taken care of.
On a side note, i have configured it to mount a ZFS vol at /var/cache/zoneminder/events.
Just wana confirm that the Filter has indeed started to work after a reboot.
Thank you for your help.
