PTZ Config
Radiotwo
PTZ Config
Post by Radiotwo »
Hi I am trying to configure the Hikvision PTZ control in the control section in V1.33.x
I have found the section for the Hikvision but the bit I cannot find the information for:
Control device
Control Address
Could anyone help please?
Steve
Screenshot-2019-1-7 ZM - Monitor - Monitor-5.png (35.18 KiB) Viewed 6070 times
vincentstans
Re: PTZ Config
Post by vincentstans »
The HikVision.pm says the following
for me this file is found @
/usr/share/perl5/ZoneMinder/Control/HikVision.pm
# HiKVision ISAPI Control Protocol
# Set the following:
# ControlAddress: username:password@camera_webaddress:port
# ControlDevice: IP Camera Model
Hope this helps you any further.
pennyzm
Re: PTZ Config
Post by pennyzm »
I am looking at getting some Hikvision PTZ cameras, were you able to get this working?
What hikvision model camera are you using?
Kind regards,
pennyzm
CancunManny
Re: PTZ Config
Post by CancunManny »
Post is a bit old, but in case people are wondering it seems some of the Hikvision cameras do work. I actually have an LaView camera, and by accident I found that there is a Hikvision one exactly the same, only thing that changes is the logo.
I set it up as a hikvision camera and got the pan and tilt to work, as well as the presets. My camera doesn't have zoom, auto focus, but if your hikvision camera has these options it seems they would work as well.
If you still interested let me know and I will post some instructions on how I got mine setup
