Just for the record, if someone else is going trough the same issue.
On a test system
apt-show-versions | grep -v buster
there were some leftovers from previous debian php packages
cpp-6:i386 6.3.0-18+deb9u1 installed: No available version in archive
gcc-6:i386 6.3.0-18+deb9u1 installed: No available version in archive
gcc-6-base:i386 6.3.0-18+deb9u1 installed: No available version in archive
libapache2-mod-php7.0:i386 7.0.33-0+deb9u3 installed: No available version in archive
libasan3:i386 6.3.0-18+deb9u1 installed: No available version in archive
libgcc-6-dev:i386 6.3.0-18+deb9u1 installed: No available version in archive
libisl15:i386 0.18-1 installed: No available version in archive
libmpfr4:i386 3.1.5-1 installed: No available version in archive
linux-compiler-gcc-6-x86:i386 4.9.168-1 installed: No available version in archive
linux-headers-4.9.0-8-686:i386 4.9.144-3.1 installed: No available version in archive
linux-headers-4.9.0-8-common:all 4.9.144-3.1 installed: No available version in archive
linux-image-4.9.0-9-686:i386 4.9.168-1 installed: No available version in archive
linux-kbuild-4.9:i386 4.9.168-1 installed: No available version in archive
perl-modules-5.24:all 5.24.1-3+deb9u5 installed: No available version in archive
php-mcrypt:all 1:7.0+49 installed: No available version in archive
php7.0:all 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-cgi:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-cli:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-common:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-gd:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-json:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-mbstring:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-mcrypt:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-mysql:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-opcache:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-readline:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-xml:i386 7.0.33-0+deb9u3 installed: No available version in archive
php7.0-zip:i386 7.0.33-0+deb9u3 installed: No available version in archive
ssmtp:i386 2.64-8+b2 installed: No available version in archive
purged all those packages
Purged also:
apache2
php
zoneminder
mariadb
started almost with a fresh system
Reinstalled zoneminder following:
https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
Had to manually install the DB.
mysql -uroot -p -e "grant select,insert,update,delete,create,alter,index,lock tables on zm.* to 'zmuser'@localhost identified by 'zmpass';"
Missed the icons from web interface
Solved following:
viewtopic.php?f=38&t=27514&p=107916&hilit=icons#p107916
The link
http://myip/zm/api/ now was working, but there was a warning about
"NOT writable Your tmp directory"
Solved following:
viewtopic.php?f=36&t=26200&p=100710&hil ... ot#p100710
and
viewtopic.php?f=38&t=27651&p=107695&hil ... mp#p107695
was missing /usr/share/zoneminder/www/api/app/tmp
Now i get the correct output from
http://myip/zm/api/host/getVersion.json
"version": "1.32.3",
"apiversion": "1.0"
Also had to get a zoneminder.conf for apache2 from a ubuntu install via iconnor's ppa for 1.32
AllowOverride All
Require all granted
</Directory>
Alias /zm/cache /var/cache/zoneminder/cache
<Directory /var/cache/zoneminder/cache>
AllowOverride None
<IfModule mod_authz_core.c>
# Apache 2.4
Require all granted
</IfModule>
<IfModule !mod_authz_core.c>
# Apache 2.2
Order deny,allow
Allow from all
</IfModule>
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
RewriteEngine on
RewriteBase /zm/api
</Directory>
RewriteEngine on
RewriteRule ^$ webroot/ [L]
RewriteBase /zm/api
</Directory>
RewriteEngine On
RewriteRule ^ index.php [L]
RewriteBase /zm/api
</Directory>
Now everything seems fine
Regards,
francis3
