The only problem I have and I cannot figure it out, is that in all modes, even in Modect mode (except in None), with 0 zones, ZM is still in Capturing mode but it doesn't really create event files (it creates video files only if I force alarms).
I have to monitor only this IP camera. If I disable it, it shows:
Modect, disabled
Capturing
I tried to reinstall ZoneMinder or delete and re-add the camera, but no luck.
Before, I had an HDD with same OS and it was fully working. I bought an SSD and installed all from zero, but I have only this problem.
Thank you
