Different resolution for the same camera?
ckilner
Post by ckilner »
Is it possible to detect motion on a low resolution and record events on a higher resolution?
BaseballSS
Re: Different resolution for the same camera?
Post by BaseballSS »
Yes. Low res monitor set to modect, high res set to nodect and linked to the low res monitor.
ckilner
Post by ckilner »
Thanks. I've configured that. I have a camera set to low res and modect, a clone of the same camera set to high res and nodect and linked to the low res copy of the camera.
The low res camera picks up movement but the linked high res version doesn't record any events.
ckilner
Post by ckilner »
I think I may have answered my own question. It seems that if I change any config parameters on the low res camera I need to unlink and relink the high res camera to it again. Not sure if there is a good reason for this but it does seem to fix the problem.
