Ok thank you , i'll try soon, but for you ,how many time need to update to the normal channel release these app?
Thank you
Zmninja connect with zoneminder multi-server
Re: Zmninja connect with zoneminder multi-server
I'm not sure what you are asking, but in general, I always make a beta release first, keep it in beta for a few weeks and then move to main production.
If you don't want to try the beta app, you can wait for 2-3 weeks and it will be there in the main App Store after that.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Good evening,
Unfortunately I had tried only now,the version for Iphone only this continue to not working...the version for Android it's ok
Oh really? That's odd, its the same code.
I don't remember - did you give me access to your server to test? IF so, can you do it again and email me so I can test with iOS ?
ES docs
zmNinja docs
ES docs
zmNinja docs
Ok i send to you in private the informations.Thank you
Works fine for me. Can you send me an email (pliablepixels@gmail) ? I'll send you a screenshot. I tried with the latest version of zmNinja for iOS (1.3.056)
ES docs
zmNinja docs
ES docs
zmNinja docs
ok i sended to you a email , did you received it?
I already responded to you via email.
ES docs
zmNinja docs
ES docs
zmNinja docs
Hi i still have the problems with some version of iphone, and Win10 64bit PRO.
I sent you email with the screeshot
Thank you for support
