Can I expand the size of Default storage.
jprainey
Post by jprainey »
Hi all,
I have an installation of ZM running on an Ubuntu 18.04 VM. When I did the initial setup, I allocated 100GB of a ~225GB SSD to the VM.
I have been adding cameras and learning about ZM ever since. (and enjoying it immensely)
I seen to have hit a little bump.
I am running 4 cameras, and have set them up to MOCORD with a 5 day filter. Everything doing well, except that I am pushing the limits of storage, using about 86% in storing events. To address this, I expanded the VM disk allocation to 200GB, and expanded /dev/sda2 partition to include the expanded space. I was surprised when ZM did not change ... it is still showing 86% usage in default (84.28GB of 97.93GB 67.13GB used by events.
Spent the last 2 hours searching for an explanation and/or a solution.
My question: Is there any way to expand Default Storage to use all of the available space in the partition?
Thanks in advance,
Jack Rainey
gbkersey
Re: Can I expand the size of Default storage.
Post by gbkersey »
You expanded the partition, but did you expand the file system? If you are using the ext4 file system (the most common), do this....
resize2fs /dev/sda2
That will expand the file system to the size of the partition.
jprainey
Post by jprainey »
Thank you gbkersey!
Worked perfectly, although I thought I had already done that.
Jack
