How to disable a Monitor in the Console panel?
friscom
Post by friscom »
Simple question: with reference to the main console, there is a small ticking box for selecting those monitors in the list that the admin can eventually delete.
Is any alternative available to temporarily turn off a monitor without deleting it?
thanks,
friscom
jameswilson
Post by jameswilson »
change its status to none (if you currently set to mocord change it to none)
friscom
Post by friscom »
Yes, thanks it works
I know, I should have known...
friscom
jameswilson
no porblem mate happy viewing
