I just moved from Android to IoS. Running 5 cameras on a Debian Server with 1.32.3, I was happy with Tiny Cam Pro (paid version) on Android. What is a good equivalent on IoS?
Thanks,
Paul
IoS replacement for Tiny Cam Pro?
Re: IoS replacement for Tiny Cam Pro?
TinyCam pro works directly with cameras (in addition to routing through ZM).
If you are looking for a replacement app look around in this forum. There are two apps, really, at this stage:
a) zmNinja (I am the author)
b) Surveillance Pro
zmNinja doesn't work directly with cameras. It only works with ZM.
No idea about Surveillance Pro
b) Surveillance Pro
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Thanks, I would not mind trying ZmNinja but I'm at 1.32.3 atm. Is there a trial or test? I don't mind paying if it works.
ES docs
zmNinja docs
ES docs
zmNinja docs
Thank you - The windows desktop version seems to be working. I will try and build the IoS version as I'm running the 13 beta.
