Cant delete using tickbox selections since update to 1.33.14
myurkoski
Post by myurkoski »
After the latest update to v1.33.14, I can no longer delete recordings using the tickboxes in the event lists. Pressing delete leads to the "are you sure you want to delete..." popup, but accepting that message results in an empty page.
Button in question below:
ZM button.png (21.66 KiB) Viewed 3447 times
Some important details:
  • A "TypeError: e[c] is undefined" error is generated in the log (See below)
    ZM Error.png (59.68 KiB) Viewed 3447 times
  • Selecting one item behaves the same as selecting 1000. Blank page, nothing gets deleted.
  • Items can still be deleted normally one at a time from the event view as they are viewed
Per the error, is my "mootool-more.js" what's at fault, and can it be repaired/replaced? Let me know what other information I can provide you. We just returned from a short trip and I can't clear the recordings without watching all 1000+ of them!
Thanks,
M Yurkoski
casino-surveillance
Re: Cant delete using tickbox selections since update to 1.33.14
Post by casino-surveillance »
Im having the same issue, hope it will be resolved soon.
events delete is fixed in master. mootools error is unrelated.
apti
Post by apti »
I just tried the update this morning and I also still have the problem. You can't delete from the tick boxes of events. Everything looks good except in the end you end up with a blank web page and the events are not deleted. I routinely delete several hundred nighttime events every day. Doing this one at a time is not very manageable. Can we please get a fix for this ASAP even if I have to write code into something?
casino-surveillance
Ive just updated my Zoneminder to latest version and the issue has been resolved, Im on Ubuntu 18.04 using Iconner PPA.
apti
Post by apti »
I am using fedora with the zoneminder repo and fix not in there it seems. I will fix myself if the fixes are published. Otherwise they need to get the fix into the zoneminder repo for fedora.
located
http://zmrepo.zoneminder.com/f/29/SRPMS
hope that helps because deleting a few hundred events everyday one at a time is time consuming.
