Camera: Generic RTSP Android App
Camera Configuration: RTSP, tcp, Camera passthrough, no framerate set. Full dump here: https://pastebin.com/aWiaciDt
Issue: Can't view stream via zms to the Monitor tab. A URL such as [1] produces an empty 200 response when normally it would stream the camera.
Logs: The primary error in the logs is
| Id | TimeKey | Component | ServerId | Pid | Level | Code | Message | File | Line |
| 16060 | 1568246086.344402 | zmc_m1 | 0 | 2711 | -2 | ERR | Unable to open input rtsp://10.1.2.2:5554 due to: Invalid data found when processing input | zm_ffmpeg_camera.cpp | 372 |
Complete Logs:
| 22430 | 1568258393.670416 | zmc_m1 | 0 | 8472 | -2 | ERR | Failed to prime capture of initial monitor |
| 22429 | 1568258393.646139 | zmc_m1 | 0 | 8472 | -2 | ERR | Unable to open input rtsp://cam-front-gate:5554 due to: Invalid data found when processing input |
| 22428 | 1568258393.405024 | zmc_m1 | 0 | 8472 | 0 | INF | Priming capture from rtsp://cam-front-gate:5554 |
| 22427 | 1568258383.374758 | zmc_m1 | 0 | 8472 | -2 | ERR | Failed to prime capture of initial monitor |
| 22426 | 1568258383.343053 | zmc_m1 | 0 | 8472 | -2 | ERR | Unable to open input rtsp://cam-front-gate:5554 due to: Invalid data found when processing input |
| 22425 | 1568258383.177687 | zmc_m1 | 0 | 8472 | 0 | INF | Priming capture from rtsp://cam-front-gate:5554 |
| 22424 | 1568258373.117898 | zmc_m1 | 0 | 8472 | -2 | ERR | Failed to prime capture of initial monitor |
| 22423 | 1568258373.091632 | zmc_m1 | 0 | 8472 | -2 | ERR | Unable to open input rtsp://cam-front-gate:5554 due to: Invalid data found when processing input |
| 22422 | 1568258372.916103 | zmc_m1 | 0 | 8472 | 0 | INF | Priming capture from rtsp://cam-front-gate:5554 |
| 22421 | 1568258362.886037 | zmc_m1 | 0 | 8472 | -2 | ERR | Failed to prime capture of initial monitor |
| 22420 | 1568258362.853391 | zmc_m1 | 0 | 8472 | -2 | ERR | Unable to open input rtsp://cam-front-gate:5554 due to: Invalid data found when processing input |
| 22419 | 1568258362.687057 | zmc_m1 | 0 | 8472 | 0 | INF | Priming capture from rtsp://cam-front-gate:5554 |
| 22418 | 1568258355.175948 | zms_m1 | 0 | 8475 | -1 | WAR | no last_frame_sent. Shouldn't happen. frame_mod was (1) frame_count (0) |
| 22417 | 1568258354.501515 | web_js | NULL | 8133 | -2 | ERR | getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-128858s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not r|
| 22416 | 1568258354.303637 | web_php | NULL | 8133 | -2 | ERR | Socket /var/lib/zoneminder/sock/zms-128858s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please ch|
| 22415 | 1568258352.648101 | zmc_m1 | 0 | 8472 | -2 | ERR | Unable to open input rtsp://cam-front-gate:5554 due to: Invalid data found when processing input |
| 22414 | 1568258352.506683 | zmc_m1 | 0 | 8472 | 0 | INF | Priming capture from rtsp://cam-front-gate:5554 |
| 22413 | 1568258352.480939 | zmc_m1 | 0 | 8472 | 0 | INF | Starting Capture version 1.33.14 |
| 22412 | 1568258352.411359 | zmc_m1 | 0 | 8472 | 0 | INF | Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor not part of your debug targets |
| 22411 | 1568258352.317420 | zmdc | NULL | 8472 | 0 | INF | 'zmc -m 1' started at 19/09/11 20:19:12 |
| 22410 | 1568258352.315350 | zmdc | NULL | 8141 | 0 | INF | 'zmc -m 1' starting at 19/09/11 20:19:12, pid = 8472 |
| 22409 | 1568258352.279070 | zmdc | NULL | 8141 | 0 | INF | Starting pending process, zmc -m 1 |
| 22408 | 1568258351.426968 | zms_m1 | 0 | 8471 | -2 | ERR | Unable to connect to zmc process for monitor 1 |
| 22407 | 1568258351.398100 | zms_m1 | 0 | 8471 | -2 | ERR | Unable to connect to monitor id 1 for streaming |
| 22406 | 1568258351.373665 | zms_m1 | 0 | 8471 | -2 | ERR | Got empty memory map file size 0, is the zmc process for this monitor running? |
| 22405 | 1568258351.170637 | web_js | NULL | 8221 | -2 | ERR | getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-221625s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not r|
| 22404 | 1568258350.649053 | web_php | NULL | 8221 | -2 | ERR | Socket /var/lib/zoneminder/sock/zms-221625s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please ch|
| 22403 | 1568258348.753119 | zms_m1 | 0 | 8468 | -2 | ERR | Unable to connect to zmc process for monitor 1 |
| 22402 | 1568258348.723958 | zms_m1 | 0 | 8468 | -2 | ERR | Unable to connect to monitor id 1 for streaming |
| 22401 | 1568258348.691320 | zms_m1 | 0 | 8468 | -2 | ERR | Got empty memory map file size 0, is the zmc process for this monitor running? |
| 22400 | 1568258348.507319 | web_js | NULL | 8221 | -2 | ERR | getStreamCmdResponse stream error: Socket /var/lib/zoneminder/sock/zms-368376s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not r|
| 22399 | 1568258348.308356 | web_php | NULL | 8221 | -2 | ERR | Socket /var/lib/zoneminder/sock/zms-368376s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please ch|
| 22398 | 1568258346.146300 | zmdc | NULL | 8141 | 0 | INF | 'zmc -m 1' exited normally |
| 22397 | 1568258346.013620 | zmdc | NULL | 8141 | 0 | INF | 'zmc -m 1' sending stop to pid 8459 at 19/09/11 20:19:06 |
| 22396 | 1568258345.823090 | zmwatch | NULL | 8182 | -1 | WAR | Restarting capture daemon for cam-front-gate, no image since startup. Startup time was 1568258337 - now 1568258345 > 5 |
| 22395 | 1568258338.060615 | zms_m1 | 0 | 8462 | -1 | WAR | no last_frame_sent. Shouldn't happen. frame_mod was (1) frame_count (0) |
| 22394 | 1568258337.371021 | web_js | NULL | 8130 | -2 | ERR | getStreamCmdResponse stream error: No data to read from socket - checkStreamForErrors() |
| 22393 | 1568258337.304134 | zmc_m1 | 0 | 8459 | -2 | ERR | Unable to open input rtsp://cam-front-gate:5554 due to: Invalid data found when processing input |
| 22392 | 1568258337.240353 | web_php | NULL | 8130 | -2 | ERR | No data to read from socket |
| 22391 | 1568258337.211544 | web_php | NULL | 8130 | -2 | ERR | Timed out waiting for msg /var/lib/zoneminder/sock/zms-638733s.sock |
| 22390 | 1568258337.091068 | zmc_m1 | 0 | 8459 | 0 | INF | Priming capture from rtsp://cam-front-gate:5554 |
| 22389 | 1568258337.058772 | zmc_m1 | 0 | 8459 | 0 | INF | Starting Capture version 1.33.14 |
| 22388 | 1568258336.986650 | zmc_m1 | 0 | 8459 | 0 | INF | Not enabling ffmpeg logs, as LOG_FFMPEG and/or LOG_DEBUG is disabled in options, or this monitor not part of your debug targets |
| 22387 | 1568258336.895950 | zmdc | NULL | 8459 | 0 | INF | 'zmc -m 1' started at 19/09/11 20:18:56 |
| 22386 | 1568258336.890650 | zmdc | NULL | 8141 | 0 | INF | 'zmc -m 1' starting at 19/09/11 20:18:56, pid = 8459 |
......./cgi-bin/zms?scale=100&width=720px&height=1280px&mode=jpeg&maxfps=30&monitor=1&connkey=624804&rand=1568256999
