{ "success": false, "data": { "name": "Not Authenticated", "message": "Not Authenticated", "url": "\/zm\/api\/host\/getVersion.json", "exception": { "class": "UnauthorizedException", "code": 401, "message": "Not Authenticated", "trace": [ "#0 [internal function]: AppController->beforeFilter(Object(CakeEvent))", "#1 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Event\/CakeEventManager.php(243): call_user_func(Array, Object(CakeEvent))", "#2 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Controller\/Controller.php(677): CakeEventManager->dispatch(Object(CakeEvent))", "#3 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Routing\/Dispatcher.php(189): Controller->startupProcess()", "#4 \/usr\/share\/zoneminder\/www\/api\/lib\/Cake\/Routing\/Dispatcher.php(167): Dispatcher->_invoke(Object(HostController), Object(CakeRequest))", "#5 \/usr\/share\/zoneminder\/www\/api\/app\/webroot\/index.php(108): Dispatcher->dispatch(Object(CakeRequest), Object(CakeResponse))", "#6 {main}" ] }, "queryLog": { "default": { "log": [ { "query": "SELECT `Config`.`Id`, `Config`.`Name`, `Config`.`Value`, `Config`.`Type`, `Config`.`DefaultValue`, `Config`.`Hint`, `Config`.`Pattern`, `Config`.`Format`, `Config`.`Prompt`, `Config`.`Help`, `Config`.`Category`, `Config`.`Readonly`, `Config`.`Requires` FROM `zm`.`Config` AS `Config` WHERE `Config`.`Name` = 'ZM_OPT_USE_API' LIMIT 1", "params": [ ], "affected": 1, "numRows": 1, "took": 0 }, { "query": "SELECT `Config`.`Id`, `Config`.`Name`, `Config`.`Value`, `Config`.`Type`, `Config`.`DefaultValue`, `Config`.`Hint`, `Config`.`Pattern`, `Config`.`Format`, `Config`.`Prompt`, `Config`.`Help`, `Config`.`Category`, `Config`.`Readonly`, `Config`.`Requires` FROM `zm`.`Config` AS `Config` WHERE `Config`.`Name` = 'ZM_OPT_USE_AUTH' LIMIT 1", "params": [ ], "affected": 1, "numRows": 1, "took": 0 }, { "query": "SELECT `Config`.`Id`, `Config`.`Name`, `Config`.`Value`, `Config`.`Type`, `Config`.`DefaultValue`, `Config`.`Hint`, `Config`.`Pattern`, `Config`.`Format`, `Config`.`Prompt`, `Config`.`Help`, `Config`.`Category`, `Config`.`Readonly`, `Config`.`Requires` FROM `zm`.`Config` AS `Config` WHERE `Config`.`Name` = 'ZM_OPT_USE_API' LIMIT 1", "params": [ ], "affected": 1, "numRows": 1, "took": 0 }, { "query": "SELECT `Config`.`Id`, `Config`.`Name`, `Config`.`Value`, `Config`.`Type`, `Config`.`DefaultValue`, `Config`.`Hint`, `Config`.`Pattern`, `Config`.`Format`, `Config`.`Prompt`, `Config`.`Help`, `Config`.`Category`, `Config`.`Readonly`, `Config`.`Requires` FROM `zm`.`Config` AS `Config` WHERE `Config`.`Name` = 'ZM_OPT_USE_AUTH' LIMIT 1", "params": [ ], "affected": 1, "numRows": 1, "took": 0 } ], "count": 4, "time": 0 } } } }
AllowOverride All
Require all granted
</Directory>
php_flag register_globals off
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
</Directory>
