log_level configuration useless ?
benoit34
Post by benoit34 »
Hi everybody,
I have a small issue with log level configuration on 1.32.3 and buster installation.
I wanted to reduce amount of log event, by moving from informational to warning in the log_level_(syslog-file-weblog-database) settings.
But nothing changed.
Whatever I choose, for syslog/file/weblog settings (even if I choose "None", I'm still having informational events in my val/log/messages or /var/log/syslog files, and in the log panel in the web interface.
Same with the log_level_database option, everything is printed in the log panel, and if I choose "None", the log panel link dissapears (so nut sur if it's still log or not).
By the way, log file are /var/log/messages and /var/log/syslog (same log write twice) and nothing in /var/log/zm.
Is it an explicable working way ?
Or did I miss something ???
By the way, ZM is really great !!
Regards,
