System: Debian Etch AMD64
Whe I try to login with any of the username/passwords in my database, I just get
the login screen redisplayed.
I can get a console by turning off authentication in the database, but that's unacceptable.
Trying to find where the failure occurs, I turned on debugging in zm.php. Below are the
php variables dumped after a login attempt. I notice that:
_SERVER["REQUEST_METHOD"] GET
even though the method in the sourece and in the access.log is POST.
_SERVER["QUERY_STRING"] no value
This is true in the access log -- there is no query string
_SERVER["argv"]
is empty.
This is the case with firefox and IE.
So my questions: Is this the reason for the login failure?
If so, where in the process are the login values likely not being forwarded?
Is my apache build whacked? or my php? or.....
If not, whare should I be looking?
Thanks.
Don
Variable Value
_REQUEST["bandwidth"] high
_REQUEST["format"] html
_REQUEST["ZMSESSID"] 46d6faae8e720027802eeec33f8b5983
_COOKIE["bandwidth"] high
_COOKIE["format"] html
_COOKIE["ZMSESSID"] 46d6faae8e720027802eeec33f8b5983
_SERVER["DOCUMENT_ROOT"] /var/www
_SERVER["HTTP_ACCEPT"] text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_COOKIE"] bandwidth=high; format=html; ZMSESSID=46d6faae8e720027802eeec33f8b5983
_SERVER["HTTP_HOST"] zoneminder.mote.org
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_REFERER"] http://zoneminder.mote.org/zm/zm.php
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.7.8) Gecko/20050518 Firefox/1.0.4 (Debian package 1.0.4-2)
_SERVER["PATH"] /bin:/usr/bin:/usr/local/bin
_SERVER["REMOTE_ADDR"] 12.174.210.200
_SERVER["REMOTE_PORT"] 38016
_SERVER["SCRIPT_FILENAME"] /var/www/zm/zm.php
_SERVER["SERVER_ADDR"] 12.174.210.138
_SERVER["SERVER_ADMIN"] don@mote.org
_SERVER["SERVER_NAME"] zoneminder.mote.org
_SERVER["SERVER_PORT"] 80
_SERVER["SERVER_SIGNATURE"] <ADDRESS>Apache/1.3.33 Server at zoneminder.mote.org Port 80</ADDRESS>
_SERVER["SERVER_SOFTWARE"] Apache/1.3.33 (Debian GNU/Linux) PHP/4.3.10-15
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_URI"] /zm/zm.php
_SERVER["SCRIPT_NAME"] /zm/zm.php
_SERVER["PATH_TRANSLATED"] /var/www/zm/zm.php
_SERVER["PHP_SELF"] /zm/zm.php
_SERVER["argv"]
Array
_SERVER["argc"] 0
_ENV["LANG"] C
_ENV["PATH"] /bin:/usr/bin:/usr/local/bin
Login broken
Login broken
Don Hayward
Mote Marine Laboratory
Hi all,
It seems that somehow my database had been corrunpted. All the passwords were 16
character "hashed" strings that did not match to output of the current mysql password
function, which is more like 32 characters with a leading '*'. I used mysql monitor to update
my Password entries and things are now functioning normally.
Don
Don
Don Hayward
- lazyleopard
I have similar problems.
Tried both compiling and running the Debian package (which depended on an old non-existing phpapi).
Compiled version 1.21.3:
Login screen is accepting "admin/admin" and then just flashes and then back to login page. Tried to set a new password directly in the database, same result.
Debian package, login screen:
I'm running Debian (unstable) with Mysql 4.1.13a-3, PHP 4.4.0.
[/code]
Warning: mysql_pconnect(): Client does not support authentication protocol requested by server; consider upgrading MySQL client in /var/www/zm/zm_db.php on line 21
Could not connect to database: Client does not support authentication protocol requested by server; consider upgrading MySQL client
[/code]
Daniel
(CISSP)
Daniel
(CISSP)
happened to me too
then, DUH, turned cookies ON and java-script ON. May not be same problem for you, but saved it for me. Life is good now.
Randy
Randy
this fixed login after debian etch upgrade foobarred it
The mysql password change fixed my login after a debian upgrade. It was returning to login screen after entering password and username. I think mysql gets upgraded from version 4 to version 5 in th etch upgrade (etch makes me itch! ).
