1.33.10 to 1.33.14
Cramac1
1.33.10 to 1.33.14
Post by Cramac1 »
everything worked.
Yesterday updated, now I can not watch online monitors.
when trying to view
http://video.site.com/zm/cgi-bin/nph-zms.....
HTTP ERROR 403
although I didn’t touch the settings, I did only update the packages on the server: apache2 and zoneminder
in zm log:
Socket /var/run/zm/zms-850214s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
Re: 1.33.10 to 1.33.14
We moved the timezone setting from php.ini to Options->System->Timezone. You need to set it there
Cramac1
Post by Cramac1 »
thx!
