console not loading correctly after upgrade
After upgrading from version 1.30.4 to 1.32.3 I just get some text after logging in, the whole console doesn't seem to load correctly. I've attached a screenshot. Upgrade seems to have gone fine, I'm wondering if there is some viewing option held over from previous version that prevents console coming up correctly? Any input would be appreciated.
- zmconsole.png (16.69 KiB) Viewed 2039 times
Re: console not loading correctly after upgrade
ZM 1.32 requires a more up to date browser than 1.30. Update browser, and try a different browser, also. If that's not it, check logs. Make sure DB updated.
I took a different approach,
1. Exported old database then imported to new server
2. upgraded the database with zmupdate.pl
2. exported each table
3. delete the database and created new with zm_create.sql
3. imported each of the already updated database tables to zm database
zoneminder now seems to be running fine.
