I have installed ZM 1.33.14 on clean Debian Buster.
All went well. I just upgraded to 1.33.15 and that went well.
My problem is with the API. I have attached a picture of what I get when I reference the URL: .../zm/api
When I reference the URL .../api/host/getVersion.json, I get:
{"success":false,"data":{"name":"Not Authenticated","message":"Not Authenticated","url":"\/zm\/api\/host\/getVersion.json","exception":{"class":"UnauthorizedException","code":401,"message":"Not Authenticated"}}}
This is my first time with ZoneMinder and it is remarkable!
The requested address '/zm/api/' was not found on this server.
- Annotation 2019-11-29 173548.png (71.92 KiB) Viewed 59582 times
Re: The requested address '/zm/api/' was not found on this server.
That is expected for the path /zm/api, as I noticed that recently. Or at least, it appears to be setup right.
Try adding authentication to the http request.
e.g.
e.g.
curl -XPOST -d "user=admin&pass=password" http://<ipaddress>/zm/api/host/getVersion.json
Thank you for the timely reply! Alas, No Joy.
- Annotation 2019-11-29 201455.png (40.27 KiB) Viewed 59570 times
What guide did you use to install? Is this on arm or x86/64?
Try the following per: https://wiki.zoneminder.com/Debian_8_64 ... ldid=14763
(This used to be required, I'm not sure if it is anymore...)
If that doesn't work, see https://github.com/pliablepixels/zmNinj ... r-with-API
Edit /etc/apache2/conf-enabled/zoneminder.conf
nano /etc/apache2/conf-enabled/zoneminder.conf
Add at the bottom:
AllowOverride All
</Directory>
"What guide did you use to install? Is this on arm or x86/64?"
Those are excellent questions! I'm sorry you had to ask them. The Guide:
https://wiki.zoneminder.com/Debian_10_B ... pro_Master
The architecture is x86_64.
I applied the suggested changes, and still No Joy.
Pliablepixels says, "if you find the page empty, your APIs/permissions have a problem." I did indeed find just JSON.
I turned off authentication (unchecked OPT_USE_AUTH), and I get Not Found instead of Not Authenticated for the same URL.
Some news: zm/api/host/getVersion.json returns {"version":"1.33.15","apiversion":"2.0"} with authentication off.
Turn the authentication back on.
Login into the ZM web console with the browser, open a new tab and use the URL http://your_ip/zm/api/host/getVersion.json and
you will see the return:
this return means the API is working as expected.
what your error message is telling us is that on your first attempt you were not logged in so there wasn't a proper login cookie created and the API returned "not authorized" which is a security feature. Once you had turned off the authorization the API did not need an authorization so it returned the proper response.
when you used /zm/api, this URL will return an error page because for better security the debug is turned off and this url is inaccessible from a browser and when you have the browser logged in to ZM and try zm/api/ you will receive an error notification, this is also for security reasons.
Double checked this today (1.32.3). The command above works, as long as you've installed ZM properly. There is no need to preface this command with a login.json. API commands can be called without logging in beforehand.snake wrote: ↑Sat Nov 30, 2019 3:50 amCode: Select all
Likely, it did not work for original poster due to OPT_AUTH not enabled / user & pass setup, or otherwise installed incorrectly.
