zm_signal.cpp nph-zms crashing
bignellrp
Post by bignellrp »
I have recently installed ZM 1.33.15 on Ubuntu 18.04 from deb file.
Ive successfully added 2 cameras which seem to be working fine. One is source type remote with rtsp and one is source type ffmpeg with http.
Im trying to add two new camera with source type ffmpeg and rtsp but getting the same crash on zm_signal.cpp nph-zms and no image.
The camera works on rtsp and onvif if i add them directly on securityspy on my mac but doesn't work on ZM.
Below are the logs from zm and /var/log/zm/zm-debug
2019-12-22 12:42:50	zmc_m1		28560	INF	FrontRoom: images:3851200 - Capturing at 12.50 fps, capturing bandwidth 290083bytes/sec	zm_monitor.cpp	2546
2019-12-22 12:42:50	zma_m1		28563	INF	FrontRoom: 3850600 - Analysing at 12.50 fps	zm_monitor.cpp	1297
2019-12-22 12:42:50	zmc_m2		17163	INF	FrontDoor: images:930200 - Capturing at 4.00 fps, capturing bandwidth 50075bytes/sec	zm_monitor.cpp	2546
2019-12-22 12:42:42	zma_m1		28563	INF	FrontRoom: 3850500 - Analysing at 12.50 fps	zm_monitor.cpp	1297
2019-12-22 12:42:42	zmc_m1		28560	INF	FrontRoom: images:3851100 - Capturing at 12.50 fps, capturing bandwidth 289454bytes/sec	zm_monitor.cpp	2546
2019-12-22 12:42:37	zmdc		21316	INF	'zma -m 7' crashed, signal 134	zmdc.pl
2019-12-22 12:42:37	zmdc		21316	INF	'zmc -m 7' crashed, signal 134	zmdc.pl
2019-12-22 12:42:37	zmc_m7		24441	INF	Enabling ffmpeg logs, as LOG_DEBUG+LOG_FFMPEG are enabled in options	zm_ffmpeg.cpp	82
2019-12-22 12:42:37	zmdc		24442	INF	'zma -m 7' started at 19/12/22 12:42:37	zmdc.pl
2019-12-22 12:42:37	zmdc		21316	INF	'zma -m 7' starting at 19/12/22 12:42:37, pid = 24442	zmdc.pl
2019-12-22 12:42:37	zmdc		21316	INF	Starting pending process, zma -m 7	zmdc.pl
2019-12-22 12:42:37	zmdc		24441	INF	'zmc -m 7' started at 19/12/22 12:42:37	zmdc.pl
2019-12-22 12:42:37	zmdc		21316	INF	'zmc -m 7' starting at 19/12/22 12:42:37, pid = 24441	zmdc.pl
2019-12-22 12:42:37	zmdc		21316	INF	Starting pending process, zmc -m 7	zmdc.pl
2019-12-22 12:42:34	zma_m1		28563	INF	FrontRoom: 3850400 - Analysing at 11.11 fps	zm_monitor.cpp	1297
2019-12-22 12:42:34	zmc_m1		28560	INF	FrontRoom: images:3851000 - Capturing at 11.11 fps, capturing bandwidth 257346bytes/sec	zm_monitor.cpp	2546
2019-12-22 12:42:27	web_php		22075	ERR	Unable to load Monitor record for Id=6	/usr/share/zoneminder/www/includes/Monitor.php	153
2019-12-22 12:42:27	web_js		24421	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-210052s.sock ) failed: Connection refused - checkStreamForErrors()	?view=watch
2019-12-22 12:42:27	web_php		22075	ERR	socket_sendto( /var/run/zm/zms-210052s.sock ) failed: Connection refused	/usr/share/zoneminder/www/includes/functions.php	2167
2019-12-22 12:42:26	zms_m6		24436	INF	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x555df83163c8 0x7f1dda505890 0x555df82b1c2b 0x555df82c5279 0x555df827ceeb 0x7f1dd6434b97 0x555df827e4ca	zm_signal.cpp	112
2019-12-22 12:42:26	zma_m2		17168	INF	FrontDoor: 930100 - Analysing at 4.00 fps	zm_monitor.cpp	1297
2019-12-22 12:42:26	zms_m6		24437	ERR	Got signal 7 (Bus error), crashing	zm_signal.cpp	52
2019-12-22 12:42:26	zms_m6		24437	ERR	Signal address is 0x7f2ef2e13004, from 0x561d99605c2b	zm_signal.cpp	83
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x561d9966a3c8]	zm_signal.cpp	104
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f2f1b328890]	zm_signal.cpp	104
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0x1b) [0x561d99605c2b]	zm_signal.cpp	104
2019-12-22 12:42:26	zms_m6		24437	INF	addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x561d9966a3c8 0x7f2f1b328890 0x561d99605c2b 0x561d99619279 0x561d995d0eeb 0x7f2f17257b97 0x561d995d24ca	zm_signal.cpp	112
2019-12-22 12:42:26	zms_m6		24437	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	111
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x561d995d24ca]	zm_signal.cpp	104
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f2f17257b97]	zm_signal.cpp	104
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xeeb) [0x561d995d0eeb]	zm_signal.cpp	104
2019-12-22 12:42:26	zms_m6		24437	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x89) [0x561d99619279]	zm_signal.cpp	104
2019-12-22 12:42:25	web_php		22063	ERR	socket_sendto( /var/run/zm/zms-846087s.sock ) failed: Connection refused	/usr/share/zoneminder/www/includes/functions.php	2167
2019-12-22 12:42:25	web_js		22063	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-846087s.sock ) failed: Connection refused - checkStreamForErrors()	?view=watch
2019-12-22 12:42:25	zmc_m2		17163	INF	FrontDoor: images:930100 - Capturing at 4.00 fps, capturing bandwidth 54345bytes/sec	zm_monitor.cpp	2546
2019-12-22 12:42:25	zma_m1		28563	INF	FrontRoom: 3850300 - Analysing at 12.50 fps	zm_monitor.cpp	1297
2019-12-22 12:42:25	zmc_m1		28560	INF	FrontRoom: images:3850900 - Capturing at 12.50 fps, capturing bandwidth 289285bytes/sec	zm_monitor.cpp	2546
2019-12-22 12:42:25	web_php		21135	ERR	Unable to load Monitor record for Id=6	/usr/share/zoneminder/www/includes/Monitor.php	153
2019-12-22 12:42:25	zms_m6		24436	ERR	Got signal 7 (Bus error), crashing	zm_signal.cpp	52
2019-12-22 12:42:25	zms_m6		24436	ERR	Signal address is 0x7f1db1ff0004, from 0x555df82b1c2b	zm_signal.cpp	83
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x555df83163c8]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f1dda505890]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0x1b) [0x555df82b1c2b]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x89) [0x555df82c5279]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xeeb) [0x555df827ceeb]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f1dd6434b97]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	ERR	Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x555df827e4ca]	zm_signal.cpp	104
2019-12-22 12:42:25	zms_m6		24436	INF	Backtrace complete, please execute the following command for more information	zm_signal.cpp	111
zm Debug
12/22/19 12:42:24.355145 zms_m6[24432].DB1-zm_monitor.cpp/514 [Monitor BackGarden has function 3,
label format = '%N - %d/%m/%y %H:%M:%S', label X = 0, label Y = 0, label size = 1,
image buffer count = 100, warmup count = 0, pre-event count = 0, post-event count = 0, alarm frame count = 1,
fps report interval = 100, ref blend percentage = 6, alarm ref blend percentage = 6, track motion = 0]
12/22/19 12:42:24.355397 zms_m6[24432].DB1-zm_zone.cpp/884 [Got 1 zones for monitor BackGarden]
12/22/19 12:42:24.368865 zms_m6[24432].DB1-zm_monitor.cpp/2391 [Loaded monitor 6(BackGarden), 1 zones]
12/22/19 12:42:24.368978 zms_m6[24432].DB1-zm_monitor.cpp/591 [Unable to map file /dev/shm/zm.mmap.6 (276486952 bytes) to locked memory, trying unlocked]
12/22/19 12:42:24.369001 zms_m6[24432].DB1-zm_monitor.cpp/594 [Mapped file /dev/shm/zm.mmap.6 (276486952 bytes) to unlocked memory]
12/22/19 12:42:24.369097 zms_m6[24432].DB1-zm_stream.cpp/289 [Trying to open the lock on /var/run/zm/zms-846087.lock]
12/22/19 12:42:24.369124 zms_m6[24432].DB1-zm_stream.cpp/312 [We have obtained a lock on /var/run/zm/zms-846087.lock fd: 7]
12/22/19 12:42:24.369199 zms_m6[24432].ERR-zm_signal.cpp/52 [Got signal 7 (Bus error), crashing]
12/22/19 12:42:24.378890 zms_m6[24432].DB1-zm_signal.cpp/63 [Signal information: number 7 code 2 errno 0 pid 1138589700 uid 32654 status 1748160873]
12/22/19 12:42:24.378924 zms_m6[24432].ERR-zm_signal.cpp/83 [Signal address is 0x7f8e43dd8004, from 0x56178515ec2b]
12/22/19 12:42:24.396984 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x5617851c33c8]]
12/22/19 12:42:24.407229 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f8e6c2ed890]]
12/22/19 12:42:24.415022 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0x1b) [0x56178515ec2b]]
12/22/19 12:42:24.423560 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x89) [0x561785172279]]
12/22/19 12:42:24.431778 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xeeb) [0x561785129eeb]]
12/22/19 12:42:24.443190 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f8e6821cb97]]
12/22/19 12:42:24.451542 zms_m6[24432].ERR-zm_signal.cpp/104 [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x56178512b4ca]]
12/22/19 12:42:24.459160 zms_m6[24432].INF-zm_signal.cpp/111 [Backtrace complete, please execute the following command for more information]
12/22/19 12:42:24.467173 zms_m6[24432].INF-zm_signal.cpp/112 [addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x5617851c33c8 0x7f8e6c2ed890 0x56178515ec2b 0x561785172279 0x561785129eeb 0x7f8e6821cb97 0x56178512b4ca]
12/22/19 12:42:25.880768 zms[24436].DB1-zm_logger.cpp/254 [LogOpts: level=DB1 effective=DB1, screen=OFF, database=INF, logfile=DB1->/var/log/zm/zm_debug.log.24436, syslog=DB9]
12/22/19 12:42:25.880883 zms[24436].DB1-zms.cpp/95 [Query: scale=100&width=1280px&height=720px&mode=jpeg&maxfps=30&monitor=6&connkey=210052&rand=1577018545]
12/22/19 12:42:25.880901 zms[24436].DB1-zms.cpp/172 [Unknown parameter passed to zms width=1280px]
12/22/19 12:42:25.880914 zms[24436].DB1-zms.cpp/172 [Unknown parameter passed to zms height=720px]
12/22/19 12:42:25.880930 zms[24436].DB1-zms.cpp/172 [Unknown parameter passed to zms rand=1577018545]
12/22/19 12:42:25.880967 zms_m6[24436].DB1-zm_logger.cpp/254 [LogOpts: level=DB1 effective=DB1, screen=OFF, database=INF, logfile=DB1->/var/log/zm/zm_debug.log.24436, syslog=DB9]
12/22/19 12:42:25.880992 zms_m6[24436].DB1-zm_utils.cpp/297 [Detected a x86\x86-64 processor with SSE3]
12/22/19 12:42:25.881426 zms_m6[24436].DB1-zm_monitor.cpp/2096 [Capture Delay!? 0.000]
12/22/19 12:42:25.881458 zms_m6[24436].DB1-zm_monitor.cpp/2118 [Got 1 for v4l_captures_per_frame]
12/22/19 12:42:25.881529 zms_m6[24436].DB1-zm_monitor.cpp/423 [monitor purpose=0]
12/22/19 12:42:25.881557 zms_m6[24436].DB1-zm_monitor.cpp/437 [mem.size(8) SharedData=600 TriggerData=560 VideoStoreData=4128 timestamps=1600 images=100x2764800 = 276480000 total=276486952]
12/22/19 12:42:25.881576 zms_m6[24436].DB1-zm_storage.cpp/94 [No id passed to Storage constructor.  Using default path /var/cache/zoneminder/events instead]
12/22/19 12:42:25.881593 zms_m6[24436].DB1-zm_monitor.cpp/441 [Storage path: /var/cache/zoneminder/events]
12/22/19 12:42:25.881606 zms_m6[24436].DB1-zm_monitor.cpp/514 [Monitor BackGarden has function 3,
12/22/19 12:42:25.881857 zms_m6[24436].DB1-zm_zone.cpp/884 [Got 1 zones for monitor BackGarden]
12/22/19 12:42:25.895097 zms_m6[24436].DB1-zm_monitor.cpp/2391 [Loaded monitor 6(BackGarden), 1 zones]
12/22/19 12:42:25.895172 zms_m6[24436].DB1-zm_monitor.cpp/591 [Unable to map file /dev/shm/zm.mmap.6 (276486952 bytes) to locked memory, trying unlocked]
12/22/19 12:42:25.895192 zms_m6[24436].DB1-zm_monitor.cpp/594 [Mapped file /dev/shm/zm.mmap.6 (276486952 bytes) to unlocked memory]
12/22/19 12:42:25.895273 zms_m6[24436].DB1-zm_stream.cpp/289 [Trying to open the lock on /var/run/zm/zms-210052.lock]
12/22/19 12:42:25.895310 zms_m6[24436].DB1-zm_stream.cpp/312 [We have obtained a lock on /var/run/zm/zms-210052.lock fd: 7]
12/22/19 12:42:25.895367 zms_m6[24436].ERR-zm_signal.cpp/52 [Got signal 7 (Bus error), crashing]
12/22/19 12:42:25.920099 zms_m6[24436].DB1-zm_signal.cpp/63 [Signal information: number 7 code 2 errno 0 pid -1308688380 uid 32541 status 1]
12/22/19 12:42:25.920127 zms_m6[24436].ERR-zm_signal.cpp/83 [Signal address is 0x7f1db1ff0004, from 0x555df82b1c2b]
12/22/19 12:42:25.928191 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x555df83163c8]]
12/22/19 12:42:25.936984 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f1dda505890]]
12/22/19 12:42:25.945246 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0x1b) [0x555df82b1c2b]]
12/22/19 12:42:25.953411 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x89) [0x555df82c5279]]
12/22/19 12:42:25.959644 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xeeb) [0x555df827ceeb]]
12/22/19 12:42:25.969891 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f1dd6434b97]]
12/22/19 12:42:25.988781 zms_m6[24436].ERR-zm_signal.cpp/104 [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x555df827e4ca]]
12/22/19 12:42:25.997144 zms_m6[24436].INF-zm_signal.cpp/111 [Backtrace complete, please execute the following command for more information]
12/22/19 12:42:26.005353 zms_m6[24436].INF-zm_signal.cpp/112 [addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x555df83163c8 0x7f1dda505890 0x555df82b1c2b 0x555df82c5279 0x555df827ceeb 0x7f1dd6434b97 0x555df827e4ca]
12/22/19 12:42:26.423478 zms[24437].DB1-zm_logger.cpp/254 [LogOpts: level=DB1 effective=DB1, screen=OFF, database=INF, logfile=DB1->/var/log/zm/zm_debug.log.24437, syslog=DB9]
12/22/19 12:42:26.423632 zms[24437].DB1-zms.cpp/95 [Query: scale=100&width=1280px&height=720px&mode=jpeg&maxfps=30&monitor=6&connkey=210052&rand=1577018545]
12/22/19 12:42:26.423650 zms[24437].DB1-zms.cpp/172 [Unknown parameter passed to zms width=1280px]
12/22/19 12:42:26.423664 zms[24437].DB1-zms.cpp/172 [Unknown parameter passed to zms height=720px]
12/22/19 12:42:26.423679 zms[24437].DB1-zms.cpp/172 [Unknown parameter passed to zms rand=1577018545]
12/22/19 12:42:26.423719 zms_m6[24437].DB1-zm_logger.cpp/254 [LogOpts: level=DB1 effective=DB1, screen=OFF, database=INF, logfile=DB1->/var/log/zm/zm_debug.log.24437, syslog=DB9]
12/22/19 12:42:26.423744 zms_m6[24437].DB1-zm_utils.cpp/297 [Detected a x86\x86-64 processor with SSE3]
12/22/19 12:42:26.424190 zms_m6[24437].DB1-zm_monitor.cpp/2096 [Capture Delay!? 0.000]
12/22/19 12:42:26.424218 zms_m6[24437].DB1-zm_monitor.cpp/2118 [Got 1 for v4l_captures_per_frame]
12/22/19 12:42:26.424294 zms_m6[24437].DB1-zm_monitor.cpp/423 [monitor purpose=0]
12/22/19 12:42:26.424325 zms_m6[24437].DB1-zm_monitor.cpp/437 [mem.size(8) SharedData=600 TriggerData=560 VideoStoreData=4128 timestamps=1600 images=100x2764800 = 276480000 total=276486952]
12/22/19 12:42:26.424340 zms_m6[24437].DB1-zm_storage.cpp/94 [No id passed to Storage constructor.  Using default path /var/cache/zoneminder/events instead]
12/22/19 12:42:26.424352 zms_m6[24437].DB1-zm_monitor.cpp/441 [Storage path: /var/cache/zoneminder/events]
12/22/19 12:42:26.424364 zms_m6[24437].DB1-zm_monitor.cpp/514 [Monitor BackGarden has function 3,
12/22/19 12:42:26.424616 zms_m6[24437].DB1-zm_zone.cpp/884 [Got 1 zones for monitor BackGarden]
12/22/19 12:42:26.437796 zms_m6[24437].DB1-zm_monitor.cpp/2391 [Loaded monitor 6(BackGarden), 1 zones]
12/22/19 12:42:26.437856 zms_m6[24437].DB1-zm_monitor.cpp/591 [Unable to map file /dev/shm/zm.mmap.6 (276486952 bytes) to locked memory, trying unlocked]
12/22/19 12:42:26.437875 zms_m6[24437].DB1-zm_monitor.cpp/594 [Mapped file /dev/shm/zm.mmap.6 (276486952 bytes) to unlocked memory]
12/22/19 12:42:26.437944 zms_m6[24437].DB1-zm_stream.cpp/289 [Trying to open the lock on /var/run/zm/zms-210052.lock]
12/22/19 12:42:26.437973 zms_m6[24437].DB1-zm_stream.cpp/312 [We have obtained a lock on /var/run/zm/zms-210052.lock fd: 7]
12/22/19 12:42:26.438033 zms_m6[24437].ERR-zm_signal.cpp/52 [Got signal 7 (Bus error), crashing]
12/22/19 12:42:26.444552 zms_m6[24437].DB1-zm_signal.cpp/63 [Signal information: number 7 code 2 errno 0 pid -220123132 uid 32558 status 389448041]
12/22/19 12:42:26.444583 zms_m6[24437].ERR-zm_signal.cpp/83 [Signal address is 0x7f2ef2e13004, from 0x561d99605c2b]
12/22/19 12:42:26.454804 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 0: /usr/lib/zoneminder/cgi-bin/nph-zms(_Z14zm_die_handleriP9siginfo_tPv+0x78) [0x561d9966a3c8]]
12/22/19 12:42:26.462687 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 1: /lib/x86_64-linux-gnu/libpthread.so.0(+0x12890) [0x7f2f1b328890]]
12/22/19 12:42:26.468904 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 2: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZNK7Monitor6GetFPSEv+0x1b) [0x561d99605c2b]]
12/22/19 12:42:26.478231 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 3: /usr/lib/zoneminder/cgi-bin/nph-zms(_ZN13MonitorStream9runStreamEv+0x89) [0x561d99619279]]
12/22/19 12:42:26.486421 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 4: /usr/lib/zoneminder/cgi-bin/nph-zms(main+0xeeb) [0x561d995d0eeb]]
12/22/19 12:42:26.494790 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 5: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7) [0x7f2f17257b97]]
12/22/19 12:42:26.503062 zms_m6[24437].ERR-zm_signal.cpp/104 [Backtrace 6: /usr/lib/zoneminder/cgi-bin/nph-zms(_start+0x2a) [0x561d995d24ca]]
12/22/19 12:42:26.513603 zms_m6[24437].INF-zm_signal.cpp/111 [Backtrace complete, please execute the following command for more information]
12/22/19 12:42:26.522993 zms_m6[24437].INF-zm_signal.cpp/112 [addr2line -e /usr/lib/zoneminder/cgi-bin/nph-zms 0x561d9966a3c8 0x7f2f1b328890 0x561d99605c2b 0x561d99619279 0x561d995d0eeb 0x7f2f17257b97 0x561d995d24ca]
fontiano
Re: zm_signal.cpp nph-zms crashing
Post by fontiano »
I've got a similar problem with a Hosafe ipcamera. No crashes on my side but poor fps and glitches using ffmpeg (sometimes disconnections). As workaround I switched to Libvlc and activated "X264 Encode" on "Storage" options.
Now it's ok. (even better than with ffmpeg on zm 1.30.4)
Production: zm 1.34.26 - Debian 11 | Test: zm 1.36.33 - Debian 12
Please update, I fixed a crash in zms in 1.33.16
