zoneminder notwork with mysql8
Re: zoneminder notwork with mysql8
I am sure your procedure is missing some steps which are needed for someone not Linux savvy.
Install instructions on the WIKI for basic server, at a minimum, or desktop with MySQL8:
https://wiki.zoneminder.com/Ubuntu_Serv ... SQL_Server
- bkjaya1952
You have missed the following line ( For php 7.3 )bbunge wrote: ↑Tue Jan 07, 2020 9:02 pm Install instructions on the WIKI for basic server, at a minimum, or desktop with MySQL8:
cp /usr/share/php7.3-mysql/mysql/*.ini /etc/php/7.3/mods-available/
Step -Installation of libmp4v2-2 is not necessary ( Already included in Zoneminder 1.33)
It is not necessary to copy the php files.bkjaya1952 wrote: ↑Sat Jan 11, 2020 9:50 amYou have missed the following linebbunge wrote: ↑Tue Jan 07, 2020 9:02 pm Install instructions on the WIKI for basic server, at a minimum, or desktop with MySQL8:
It is necessary to install libmp4v2-2 for video writing and it is a dependency of Zoneminder.
- bkjaya1952
I have prepared a Zoneminder docker image with mysql 8 and pushed to the Docker Hub. Please try it and make any suggestions.
This image can be used successfully in Ubuntu 19.10.
https://hub.docker.com/r/bkjaya1952/doc ... 7.4-mysql8
- bkjaya1952
Today (23-01-2020), Mr. Isaac Connor has published the first successful Zoneminder-master-eoan package for Ubuntu 19.10. in his website.
https://launchpad.net/~iconnor/+archive ... der-master
You can get more details on installation of zoneminder 1.34 with mysql 8 on Ubuntu 19.10 ,from the following links
https://bkjaya.wordpress.com/2020/01/23 ... h-mysql-8/
https://wiki.zoneminder.com/File:Zonemi ... -_2020.pdf
yeha!!!
Unfortunatly i roll back my system!
