problem after upgrade accessing cgi-bin URL
Mozart
Post by Mozart »
I upgraded zm from 1.32 to 1.34 and that went well. Only thing is that the following entry on a webpage does not work anymore:
 http://zm05.home.intra/zm/cgi-bin/nph-zms?mode=jpeg&maxfps=5&monitor=6&user=user&pass=pass
This used to work without a problem but not anymore. I saw on the documentation that there is a new way with a auth code but that code expires and is not useful when you want to include a stream on a webpage.
If I open the url in a browser I get http error 403.
The api does work I think because I use zmNinja and that still works.
How can I troubleshoot this or is there a different way to get the same result?
Update:
I installed a new Zoneminder 1.34 on Ubuntu 18 and there it does work. Now I have two options:
1. Find the difference between the two
2. Migrate all cams, users and settings from the old to the new server
Re: API problem after upgrade
Do not think the issue is related to API.
I use this code for a camera wall:
<html>
<meta http-equiv="refresh" content="300">
<body>
<p>Backyard</p>
<img src="http://192.168.50.2/zm/cgi-bin/nph-zms? ... 1579444465">
</body>
</html>
Actually I use two cams but just show one. I enabled OPT_USE_AUTH with AUTH_RELAY of None. Created a user with password with View Stream only. Logged in as that user, opened a monitor, right clicked on the video stream, selected view image and used that URL for the img src=
The "user" did not have API enabled.
Maybe the resulting URL changed when you upgraded?
Tested on Ubuntu 18.04 with Mariadb Server and Zoneminder 1.34.0 (fresh install). Am also using this same method on a Pi 3b+ with Buster and ZM 1.33.16.
Mozart
Post by Mozart »
I tried that as well but just does not work. I also did a compare of the Apache config files but could not find a difference.
there has been changes to methods of passing authority. Take a look in Options/Systems that the legacy authority system is enable
That really should work. I'll look into it tomorrow
asker
Post by asker »
Works for me.
Please read before posting:
ES docs
zmNinja docs
Mozart
Post by Mozart »
These are the settings of the system that does not work:
These are the settings of the system that does work:
I see no difference in options so it must be something else.
Try auth_relay none
Harold Marshall
Post by Harold Marshall »
Same problem here. A fresh install + just installed Event Server succesfully -> trying to get zmNinja working. 1.34 on Ubuntu 19.10.
Mozart
Post by Mozart »
bbunge wrote: Wed Jan 22, 2020 10:23 pm Try auth_relay none
That solved it for me and since it is an internal system I don’t mind but it should also work with hashed anyway.
Harold Marshall wrote: Thu Jan 23, 2020 4:40 pm Same problem here. A fresh install + just installed Event Server succesfully -> trying to get zmNinja working. 1.34 on Ubuntu 19.10.
As I stated earlier the OP's issue was not with the API.
Make sure you have the latest ZmNinja. Make sure you have enabled the API for the ZmNinja user.
Mozart
Post by Mozart »
bbunge wrote: Thu Jan 23, 2020 7:25 pm
That’s correct, zmNinja works on both systems.
vvchumanov
Re: problem after upgrade accessing cgi-bin URL
Post by vvchumanov »
who fix this ???
i'm try all...
and video on wall work's, but on events and single camera tab don't works
volfan6415
Post by volfan6415 »
has this been fixed? Or is the only way to make this work is to turn of Auth_hashing?
gintibande
Post by gintibande »
I also did a compare of the Apache config files but could not find a difference. mobdro apk
