Trying To Upgrade From 1.32.3 to 1.34.0
security_dude
Post by security_dude »
Keeps crashing at 97% and the ESX host powers down the vm saying "There is not enough space" I have plenty of space, not sure what is going on.
Filesystem Size Used Avail Use% Mounted on
udev 7.9G 0 7.9G 0% /dev
tmpfs 1.6G 1.2M 1.6G 1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv 884G 659G 181G 79% /
tmpfs 7.9G 1.1G 6.8G 14% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 7.9G 0 7.9G 0% /sys/fs/cgroup
/dev/loop0 90M 90M 0 100% /snap/core/8213
/dev/loop1 90M 90M 0 100% /snap/core/8268
/dev/sda2 976M 145M 765M 16% /boot
tmpfs 1.6G 0 1.6G 0% /run/user/1000
security_dude
Re: Trying To Upgrade From 1.32.3 to 1.34.0
Nobody knows? From what I posted does it look like I have any space issues? I don't see it but if you do maybe point it out to me please?
lbm
Post by lbm »
Can you post the error log output ?
Im uncertain, from where you get these errors ?
Look to a forum for the VM you are using. Should not be Zoneminder issue. You could also try not using a VM.
