Issue with upgrade 1.32 to 1.34
hagak
Post by hagak »
I recently upgraded to 1.34 from 1.32. I ran zmupdate.pl and it ran without error, if I re-run zmupdate.pl it shows that I am on the latest version 1.34.
However my API interface has issues:
curl http://server/zm/api/host/getVersion.json
{"version":"1.34.0","apiversion":"2.0"}
curl http://server/zm/api/monitors.json
{"success":false,"data":{"name":"An Internal Error Has Occurred.","message":"An Internal Error Has Occurred.","url":"\/zm\/api\/monitors.json","exception":{"class":"PDOException","code":"42S22","message":"SQLSTATE[42S22]: Column not found: 1054 Unknown column 'Monitor.DefaultView' in 'field list'"}}}
This leads me to believe I have some issue with my DB schema. Any ideas on how to correct this?
hagak
Re: Issue with upgrade 1.32 to 1.34
Post by hagak »
I reran zmupdate.pl using the --version=1.32.0 to force it to run again. I then restarted mysql and zm and it has resovled this issue.
