Good Morning!
I have a camera here that I can get to work on the zoneminder. It is working by ffmpeg, but it only updates the image every 5 seconds.
They know how to tell me how to put the camera faster.
thanks
helps set up
Re: helps set up
Camera make and model? Settings used in Zoneminder?
Linux distro and version?
Re: helps set up
I'm using linux mint 19.3 and the camera is szsinocam ipc-5007w20eu.
on vlc and ispy it works fine, but on zoneminder it's slow
- foto2.png (33.24 KiB) Viewed 1894 times
- foto1.png (31.95 KiB) Viewed 1894 times
Re: helps set up
Method should be TCP
Maximum FPS blank
Alarm Maximum FPS blank
Maximum FPS blank
