My first camera
Re: My first camera
There's no wifi option in that camera?
Re: My first camera
Review https://wiki.zoneminder.com/Hardware_Compatibilty_List
to see existing Hikvision paths. It's likely to work. There should also be a user manual for the camera that documents the path. Their cameras are fairly well supported. I would recommend you purchase 1 camera, test that it works, then buy any more necessary.
You don't want to use wifi with cctv cameras. Avoid wifi whenever possible.
