I've been enjoying zoneminder for the past few years. I've just upgraded from a working zm 1.32 to 1.34. Now all my cameras show off line.
I'm also unable to view any stored events.
sudo zmupdate.pl yields: "Database already at version 1.34.2, update skipped."
I'm running:
Ubuntu 16.04 LTS,
Intel NUC Kit NUC6i3SYH BOXNUC6I3SYH
13 IP cameras from AMCREST
source like: rtsp://user:password@192.168.x.xx:554/cam/realmonitor?channel=1&subtype=1
Can you help me please?
--Tim
All Cameras Offline after 1.32 -> 1.34 upgrade
Re: All Cameras Offline after 1.32 -> 1.34 upgrade
You are going to have to report the contents of your logs. We are not psychic.
Thank you for the prompt response. I've reset passwords, tried setting auth to "no", but I'm still stuck
Here is a snippet of the current log.
2020-02-11 14:39:47.936942 zmc_m20[6789].INF-zm_monitor.cpp/2546 [Front door: images:1000 - Capturing at 20.00 fps, capturing bandwidth 55345bytes/sec]
2020-02-11 14:39:47.874760 zma_m19[6784].INF-zm_monitor.cpp/1297 [Gate: 1700 - Analysing at 33.33 fps]
2020-02-11 14:39:47.473550 zms_m19[7576].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.426590 zms_m7[7575].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.413274 zms_m6[7574].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.381738 zms_m16[7573].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.371868 zms_m1[7571].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.369109 zms_m17[7572].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.338349 zms_m4[7570].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.263346 zms_m18[7569].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.251232 zms_m5[7568].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.249912 zms_m14[7567].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.237941 zms_m21[7565].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.228535 zms_m3[7566].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.191397 zms_m20[7564].ERR-zms.cpp/215 [Unable to authenticate user]
2020-02-11 14:39:47.107704 zma_m17[6764].INF-zm_monitor.cpp/1297 [Rear Entry: 1700 - Analysing at 25.00 fps]
2020-02-11 14:39:47.031292 zma_m20[6794].INF-zm_monitor.cpp/1297 [Front door: 900 - Analysing at 16.67 fps]
2020-02-11 14:39:47.030977 zma_m16[6754].INF-zm_monitor.cpp/1297 [Office: 1700 - Analysing at 25.00 fps]
THe Unable to auth user is pretty clear, but shouldn't show up if you've turned auth to no. I suspect you havn't updated your timezone setting: Options->System->Timezone
Thanks for the reply. I did update the time zone and restarted the server with no effect.
I just reset the password for the user (me) and restarted the server. It works now.
--Tim
--Tim
I had to do the same thing - update the TZ and reset the passwords when I upgraded from 1.32.4 to 1.34.2 docker image.
"Me too" - setting the timezone in the /etc/php/*/(cli|apache2)/php.ini to the same tz as the zm options, seemed to fix, after a password change.
I have the same problem, but I haven't upgraded. I installed 1.34.6 directly.
When reboot it works, but after a little bit of new camera offline
in log e Camera Offline.ERR [zms_m3] [Unable to authenticate user]
