Zmninja Certification error
NXT
Post by NXT »
Can somebody help me with this error?
When I run this command to test the event server manual "sudo -u www-data ./zmeventnotification.pl --config ./zmeventnotification.ini"
Thanks!
asker
Re: Zmninja Certification error
Post by asker »
Please read before posting:
ES docs
zmNinja docs
NXT
Post by NXT »
thanks for the reply.
So my settings are correct?
I tried this but still the same issue.
For this scenario, this should have been enough!
sudo chown -R www-data:root /etc/letsencrypt/
I did above and the manual start was working fine.
NXT
Post by NXT »
Ok now its working.
So I did the test and I got the "Tick end" message.
I opened ZMninja on my phone its asked it was allowed to send notification. "I approved".
But still no notifications on my phone.
asker
Post by asker »
ES docs
zmNinja docs
NXT
Post by NXT »
Did some more checks.
Looks like I don’t have the tokens.txt file.
How can I fix that?
Thanks!
Kind regards,
asker
Post by asker »
tokens.txt is created when mobile phones running zmNinja register with the ES.
If that is not happening, your zmNinja mobile app is not able to connect to the ES. Check debug logs on both sides when zmNinja starts.
NXT wrote: Tue Mar 03, 2020 11:13 pm Hi,
How can I fix that?
Thanks!
Kind regards,
ES docs
zmNinja docs
