sync failure
jameswilson
sync failure
Post by jameswilson »
ep 5 20:56:51 zm zma_m1[24692]: INF [Warming up]
Sep 5 20:57:49 zm zma_m1[24692]: INF [Front: 143 - Gone into prealarm state]
Sep 5 20:58:55 zm zma_m4[5265]: INF [Got signal (Terminated), exiting]
Sep 5 20:58:55 zm zma_m4[24811]: INF [Debug Level = 0, Debug Log = <none>]
Sep 5 20:58:55 zm zma_m4[24811]: INF [Warming up]
Sep 5 20:59:14 zm zmc_d0[5237]: INF [Front: 191000 - Capturing at 2.27 fps]
Sep 5 20:59:14 zm zmc_d0[5237]: INF [Left: 191000 - Capturing at 2.27 fps]
Sep 5 20:59:14 zm zmc_d0[5237]: INF [Rear: 191000 - Capturing at 2.27 fps]
Sep 5 20:59:14 zm zmc_d0[5237]: INF [Right: 191000 - Capturing at 2.27 fps]
Sep 5 20:59:46 zm zmc_d0[5237]: INF [Got TERM signal, exiting]
Sep 5 20:59:46 zm zmc_d0[5237]: ERR [Sync failure for frame 5 buffer 5(1): Interrupted system call]
Sep 5 20:59:46 zm zma_m3[23667]: INF [Rear: 3509 - Gone into alarm state]
Sep 5 20:59:46 zm zmc_d0[24878]: INF [Debug Level = 0, Debug Log = <none>]
Sep 5 20:59:46 zm zmc_d0[24878]: INF [Starting Capture]
Sep 5 20:59:47 zm zma_m1[24692]: INF [Got signal (Terminated), exiting]
Sep 5 20:59:47 zm zma_m3[23667]: INF [Rear: 3510 - Gone into alert state]
Sep 5 20:59:47 zm zma_m1[24886]: INF [Debug Level = 0, Debug Log = <none>]
Sep 5 20:59:47 zm zma_m1[24886]: INF [Warming up]
Sep 5 20:59:51 zm zma_m3[23667]: INF [Rear: 3520 - Left alarm state (295) - 21(1) images]
Sep 5 20:59:58 zm zma_m1[24886]: INF [Front: 026 - Starting new event 296]
Sep 5 21:00:00 zm zma_m1[24886]: INF [Ended event]
Sep 5 21:00:00 zm zma_m1[24886]: INF [Front: 030 - Starting new event 297]
Sep 5 21:00:30 zm zmc_d0[24878]: INF [Got TERM signal, exiting]
Sep 5 21:00:30 zm zmc_d0[24878]: ERR [Sync failure for frame 6 buffer 6(1): Interrupted system call]
Sep 5 21:00:30 zm zmc_d0[24972]: INF [Debug Level = 0, Debug Log = <none>]
Sep 5 21:00:31 zm zmc_d0[24972]: INF [Starting Capture]
Sep 5 21:00:31 zm zma_m1[24886]: INF [Got signal (Terminated), exiting]
Sep 5 21:00:31 zm zma_m1[24980]: INF [Debug Level = 0, Debug Log = <none>]
Sep 5 21:00:31 zm zma_m1[24980]: INF [Warming up]
Sep 5 21:01:00 zm CROND[25026]: (root) CMD (nice -n 19 run-parts /etc/cron.hourly)
I am getting the above and the odd missed modect event. It logs the evnt but doesnt save any images regarding the event. It appears to only be happening on input 1
there are 4 identical cams on the machine.
im thinking it maybe the cam as it says sync loss but im not sure. I have searched but came up short.
Any clues experts??
James
jameswilson
sorted
It appears after some sql corruption thet the buffers had altered to ver the set amount
James
