User's language can not setup
sipi
Post by sipi »
I updated zm 1.32.3 to 1.34.2 and installed all update what released. Last update was 1.34.5.
I used individual language setup for users but after update all user language are default. I can not change it but removed the comment two row in skin.php.
I restarted zm, deleted user and create it newly nothing changed. Please help.
Ubuntu 18.04 x86_64, zm 1.34.5
Thanks for help.
Re: User's language can not setup
Selecting languages works for me.
Is anything logged?
Which language are you selecting?
sipi
Post by sipi »
Nothing logged... The setting appears to the user, but the interface language does not change and there is nothing in the log.
I tried Hungarian (hu_hu) and German (de_de) languages for user.
If I change LANG_DEFAULT then default language change but can't change individual language for user...
Confirmed. I will investigate.
Problem found, fix will be in 1.34.6
sipi
Post by sipi »
Thank you for your help.
sipi
Post by sipi »
zm 1.34.6 update arrived tonight but the user language selection still does not work...
What is the problem?
Tanks for help.
Regards
