Here's a PTZ control script based on the onvif.pm already available. My IPC is a DAHUA model P2 (equivalent to an IPC-AW12W), but this should be working with any dome like ptz IPC from Dahua, as long as you can control it with API HTTP commands. I strongly advise you to test the http control of your camera in a browser, using API commands listed in below documentation.
My ZM is v1.30.4, on Ubuntu 16.04 LTS server.
With this script you should control following functions on your ipc :
- Pan move
- Tilt move
- Diagonal move
- Zoom in and out
- Brightness +/-
- Contrast +/-
- Presets (goto and set)
- Reboot
HTTP commands are based on last DAHUA API for IPC doc (dahua_http_api_for_ipc_v1.56.pdf, downloadable from here:
https://www.telecamera.ru/bitrix/compon ... n=download).
I will not guide you through all the installation process of a control script as this has already been covered, and you can check ZM doc. Here is the code that should be placed in a proper .pm file, in control folder:
# ZoneMinder ONVIF Control Protocol Module
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
# This module contains the implementation of the ONVIF device control protocol
# for a DAHUA P2 (PTZ dome like IPC)
package ZoneMinder::Control::onvif;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Control;
our %CamParams = ();
# ONVIF Control Protocol
# Control Address field on Control tab should be like :
# admin:password@192.168.1.XX:80
# adjust with your own parameters (IP, port, user...)
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
my $logindetails = "";
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $class = ref( ) || croak( "$self not object" );
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
# this line tells how API http orders will be passed to the camera
if ( $res->is_success )
$result = !undef;
else
return( $result );
#autoStop
#To Auto Stop you need to fill Timeout field with a value in Control Tab. This is used to stop a continuous movement
sub autoStop
my $self = shift;
my $stop_command = shift;
my $autostop = shift;
if( $stop_command && $autostop)
Debug( "Auto Stop" );
usleep( $autostop );
# this line is used to stop a specific movement/command that is already launched
my $cmd = "cgi-bin/ptz.cgi?action=stop&channel=0".$stop_command;
$self->sendCmd( $cmd );
# Reboot the Camera
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "cgi-bin/magicBox.cgi?action=reboot";
#Up Arrow
sub moveConUp
my $self = shift;
# you can change the speed of movement 1-8 with arg 2, same for Down, Right...
my $stop_command = "&code=Up&arg1=0&arg2=1&arg3=0&arg4=0";
Debug( "Move Up" );
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=Up&arg1=0&arg2=1&arg3=0&arg4=0";
$self->autoStop( $stop_command, $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
my $self = shift;
my $stop_command = "&code=Down&arg1=0&arg2=1&arg3=0&arg4=0";
Debug( "Move Down" );
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=Down&arg1=0&arg2=1&arg3=0&arg4=0";
#Left Arrow
sub moveConLeft
my $self = shift;
my $stop_command = "&code=Left&arg1=0&arg2=1&arg3=0&arg4=0";
Debug( "Move Left" );
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=Left&arg1=0&arg2=1&arg3=0&arg4=0";
#Right Arrow
sub moveConRight
my $self = shift;
my $stop_command = "&code=Right&arg1=0&arg2=1&arg3=0&arg4=0";
Debug( "Move Right" );
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=Right&arg1=0&arg2=1&arg3=0&arg4=0";
#Zoom In
sub zoomConTele
my $self = shift;
my $stop_command = "&code=ZoomTele&arg1=0&arg2=1&arg3=0&arg4=0";
Debug( "Zoom Tele" );
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=ZoomTele&arg1=0&arg2=1&arg3=0&arg4=0";
#Zoom Out
sub zoomConWide
my $self = shift;
my $stop_command = "&code=ZoomWide&arg1=0&arg2=1&arg3=0&arg4=0";
Debug( "Zoom Wide" );
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=ZoomWide&arg1=0&arg2=1&arg3=0&arg4=0";
#Diagonally Up Right Arrow
sub moveConUpRight
my $self = shift;
my $stop_command = "&code=RightUp&arg1=1&arg2=1&arg3=0&arg4=0";
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=RightUp&arg1=1&arg2=1&arg3=0&arg4=0";
#Diagonally Down Right Arrow
sub moveConDownRight
my $self = shift;
my $stop_command = "&code=RightDown&arg1=1&arg2=1&arg3=0&arg4=0";
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=RightDown&arg1=1&arg2=1&arg3=0&arg4=0";
#Diagonally Up Left Arrow
sub moveConUpLeft
my $self = shift;
my $stop_command = "&code=LeftUp&arg1=1&arg2=1&arg3=0&arg4=0";
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=LeftUp&arg1=1&arg2=1&arg3=0&arg4=0";
$self->autoStop( $stop_command, $self->{Monitor}->{AutoStopTimeout} );}
#Diagonally Down Left Arrow
sub moveConDownLeft
my $self = shift;
my $stop_command = "&code=LeftDown&arg1=1&arg2=1&arg3=0&arg4=0";
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=LeftDown&arg1=1&arg2=1&arg3=0&arg4=0";
#Stop, for center button on control panel
sub moveStop
my $self = shift;
Debug( "Move Stop" );
# you can put any kind of code to stop the camera, I put Up by default.
my $cmd = "cgi-bin/ptz.cgi?action=stop&channel=0&code=Up&arg1=0&arg2=1&arg3=0";
#Goto preset
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=GotoPreset&arg1=0&arg2=$preset&arg3=0";
#Set Camera Preset
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "cgi-bin/ptz.cgi?action=start&channel=0&code=SetPreset&arg1=0&arg2=$preset&arg3=0";
# Increase Brightness
sub irisAbsOpen
my $self = shift;
my $params = shift;
my $step = $self->getParam( $params, 'step' );
$CamParams{'brightness'} += $step;
$CamParams{'brightness'} = 100 if ($CamParams{'brightness'} > 100);
Debug( "Iris $CamParams{'brightness'}" );
# if this has no action on your camera, try to play with the [2] that could be either 0 or 1
# you can also check with this HTTP command : /cgi-bin/configManager.cgi?action=getConfig&name=VideoColor
my $cmd = "cgi-bin/configManager.cgi?action=setConfig&VideoColor[0][2].Brightness=".$CamParams{'brightness'};
# Decrease Brightness
sub irisAbsClose
my $self = shift;
my $params = shift;
$CamParams{'brightness'} -= $step;
$CamParams{'brightness'} = 0 if ($CamParams{'brightness'} < 0);
# Increase Contrast
sub whiteAbsIn
my $self = shift;
my $params = shift;
$CamParams{'contrast'} += $step;
$CamParams{'contrast'} = 100 if ($CamParams{'contrast'} > 100);
Debug( "Iris $CamParams{'contrast'}" );
my $cmd = "cgi-bin/configManager.cgi?action=setConfig&VideoColor[0][2].Contrast=".$CamParams{'contrast'};
# Decrease Contrast
sub whiteAbsOut
my $self = shift;
my $params = shift;
$CamParams{'contrast'} -= $step;
$CamParams{'contrast'} = 0 if ($CamParams{'contrast'} < 0);
1;
Remarks:
- use "white" control to adjust brightness (confusing as DAHUA IPC also have a white balance feature... better keep camera real WB in auto mode)
- use "iris" control to adjust contrast
- adjust range (0-100) for both brightness and contrast
- an improvement could be to use the tour/patrol commands of Dahua, but I do not use this feature...
- depending on your network/speed, you may want to decrease the resolution to avoid lag, or better use the PTZ presets
- feel free to adjust the number of presets
- Thanks to the guy who wrote original onvif.pm
