Correct upgrade procedure from 1.32.3 to 1.34.4
p51mustang
Post by p51mustang »
I have 1.32.3 running well for some time but would like to upgrade. I've tried searching but can't seem to find a definitive procedure for upgrading to 1.34.x
I'm running ZM on Ubuntu 18.04 running on a desktop PC.
lsb_release -d
Description: Ubuntu 18.04.1 LTS
mysql --version
mysql Ver 14.14 Distrib 5.7.24, for Linux (x86_64) using EditLine wrapper
apache2 -v
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2018-10-10T18:59:25
php --version
PHP 7.2.10-0ubuntu0.18.04.1 (cli) (built: Sep 13 2018 13:45:02) ( NTS )
From what I have been able to gather the procedure to upgrade should be something like this:
1. Stop zoneminder
2. Add the repository - sudo add-apt-repository ppa:iconnor/zoneminder-1.34
3. Install the upgrade - sudo apt-get install --only-upgrade zoneminder
4. Start zoneminder
Is there anything that I'm missing?
Thank you very much for any insights.
Re: Correct upgrade procedure from 1.32.3 to 1.34.4
This has been answered before.
Remove the 1.32 ppa
Add the 1.34 ppa
apt upgrade
apbb2
Post by apbb2 »
p51mustang
apbb2 wrote: Mon Mar 02, 2020 7:22 pm viewtopic.php?f=40&t=28942
Thank you very much for the link. I followed this and was able to upgrade without issues.
Luv2ZM
Post by Luv2ZM »
Ran into a database issue with update from 1.32.3 to 1.34.16, solution here: viewtopic.php?f=40&t=28942&start=30#p115801
juanboy2k
Post by juanboy2k »
Does it matter if you upgrade the OS (16.04.4 to 18.04.4 ubuntu) before or after doing this update? I'm also at 1.32.3... thanks!
MrMagoo
Post by MrMagoo »
My personal choice would be to update the OS first and try to end up on an LTS version of Ubuntu, I have Ubuntu 18.04.4 LTS
These are the steps I used to patch the OS then upgrade ZM
apt-get update
apt-get upgrade
All went well but there seemed to a a 24 hour period where the web interface seemed sluggish, now much more responsive.
LF-X
Post by LF-X »
would this also work on an ARM based SBC? Using an Odroid HC1 with 1.32 and 5 cams, but would like to go to 1.34.
burger
Post by burger »
LF-X wrote: Mon Aug 24, 2020 7:54 am would this also work on an ARM based SBC? Using an Odroid HC1 with 1.32 and 5 cams, but would like to go to 1.34.
viewtopic.php?f=40&t=29818
Backup the DB, and then go ahead and upgrade. If there's any errors, read the logs, then search here.
fastest way to test streams:
