"download video" and "export"
asunturd
Post by asunturd »
FYI:
just installed 1.34.3 for Centos8
Followed the readme and all seemed to work fine but:
When I tried to "download video" from "Events" it prepared the ZIP and downloaded the file,
the file seemed to be "empty", 1kb of download.
it created a zmExport_XXXXX.zip with named folder inside and a zmFileList.txt:
/var/lib/zoneminder/temp/zmExport_41059/zmFileList.txt
it also includes a numebered folder which was empty.
after reading the web instructions I found out that ffmpeg is recommended and should be enabled
I checked the "Options" and "Images"->OPT_FFMPEG and PATH_FFMPEG which both were correct set
I checked that I had the ffmpeg installed and it was.
Unchecking the OPT_FFMPEG box, saving and rechecking and saving seems to have fixed the issue but only for new events.
old events still dont work
I've tried to delete the contents of the "zoneminder/temp" folder with no luck
the "temp"-folder contains no videoes/images for the "empty" files downloaded:
bolds are the empty and correct files created:
total 19232
drwx------. 7 apache apache 229 Mar 5 17:49 .
drwxr-xr-x. 6 apache apache 56 Mar 5 10:53 ..
drwx------ 3 apache apache 38 Mar 5 17:46 zmExport_224307
-rw-r--r-- 1 apache apache 592 Mar 5 17:46 zmExport_224307.zip
drwx------ 3 apache apache 129 Mar 5 17:40 zmExport_315064
-rw-r--r-- 1 apache apache 18999601 Mar 5 17:40 zmExport_315064.zip
drwx------ 3 apache apache 38 Mar 5 17:49 zmExport_581104
drwx------ 3 apache apache 38 Mar 5 17:39 zmExport_582857
-rw-r--r-- 1 apache apache 682346 Mar 5 17:39 zmExport_582857.zip
drwx------ 3 apache apache 38 Mar 5 17:39 zmExport_695280
-rw-r--r-- 1 apache apache 592 Mar 5 17:39 zmExport_695280.zip
tried different internet browsers
"export" does work for both old and new events
PS: "download video" as "tar" results in "Export Failed" message
The system:
latest minimal installation of Centos8.1 as of per 2020-03-05 (+1 CET)
zmExport_224307.zip
(592 Bytes) Downloaded 474 times
imellor
Re: "download video" and "export"
Post by imellor »
I'm watching this with interest. I am a newbie and have installed 1.34.5, I can export video to TAR, but not ZIO. My ZIP export also come up empty
Ian
asunturd
Post by asunturd »
imellor wrote: Fri Mar 06, 2020 5:26 pm I'm watching this with interest. I am a newbie and have installed 1.34.5, I can export video to TAR, but not ZIO. My ZIP export also come up empty
Ian
Try to disable and enable the ffmpeg settings as mentioned in the post
imellor
Post by imellor »
Yes I ahve tried that.
ffmpeg is not involved in export.
Export just copies(hard links if possible) the event data to a tmp dir structure and zips or tars it up with a few html pages for viewing.
So if your zip or tar has empty directories then there must have been a failure copying the event files.
There will be logs. LOOK at them, and post them here.
I tested, and this works fine for me on ubuntu, so it is going to take some investigation.
imellor
Post by imellor »
Thank you, I have just tried a few times again. This time TAR is not working either.
The errors in my log are:
Date/Time
Component	Server	PID	Level	Message	File	Line
2020-03-07 19:32:16	web_js		779	ERR	Uncaught TypeError: Cannot read property 'getImageData' of undefined	zm/cache/skins_classic_views_js_montagereview-classic-1582749735.js	334
2020-03-07 19:30:04	web_js		1067	ERR	Uncaught RangeError: Maximum call stack size exceeded	zm/tools/mootools/mootools-core.js	1
2020-03-07 19:27:20	web_js		775	ERR	Uncaught RangeError: Maximum call stack size exceeded	zm/tools/mootools/mootools-core.js	1
2020-03-07 19:27:17	web_js		1067	ERR	Uncaught RangeError: Maximum call stack size exceeded	zm/tools/mootools/mootools-core.js	1
2020-03-07 19:27:12	web_js		779	ERR	Uncaught RangeError: Maximum call stack size exceeded	zm/tools/mootools/mootools-core.js	1
2020-03-07 19:27:05	web_js		779	ERR	Uncaught TypeError: Cannot read property 'getImageData' of undefined	zm/cache/skins_classic_views_js_montagereview-classic-1582749735.js	334
asunturd
Post by asunturd »
iconnor wrote: Sat Mar 07, 2020 1:31 pm ffmpeg is not involved in export.
something isn't right here, that for sure.
I upgraded to 1.34.5 yesterday, upgraded the database and all looked fine.
I'm testing for now but somehow "old/deleted" storage/monitor events just appear in the log:
I only have monitor ids 4 and 8 available but zoneminder logs about monitor 6, yesterday, it complained about a storage id which I had deleted.
2020-03-08 20:56:06	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:56:06	zmcontrol_6		16288	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:53:25	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:53:25	zmcontrol_6		15906	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:52:05	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:52:05	zmcontrol_6		15716	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:51:25	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:51:25	zmcontrol_6		15616	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:51:04	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:51:04	zmcontrol_6		15566	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:50:54	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:50:54	zmcontrol_6		15542	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:50:49	zmdc		11114	ERR	'zmcontrol.pl --id 6' exited abnormally, exit status 255	zmdc.pl
2020-03-08 20:50:49	zmcontrol_6		15528	FAT	Unable to load control data for monitor 6	zmcontrol.pl
2020-03-08 20:47:41	zms_e76		15062	ERR	Unable to send raw frame 157: Broken pipe	zm_eventstream.cpp	791
2020-03-08 20:47:33	zms_e76		15057	ERR	Unable to send raw frame 7: Broken pipe	zm_eventstream.cpp	791
2020-03-08 20:47:30	zms_e76		15050	ERR	Unable to send raw frame 1: Broken pipe	zm_eventstream.cpp	791
2020-03-08 20:39:49	zma_m4		13886	ERR	No diff between time_diff = 0.000000 (0:1583696389.868393 - 0:1583696389.868393), ibc: 20	zm_monitor.cpp	908
2020-03-08 20:39:49	zmwatch		11174	ERR	Last analyse time for 4 Front-Driveway was zero.	zmwatch.pl
2020-03-08 20:39:44	zmc_m4		13883	ERR	Unable to get response, disconnecting	zm_remote_camera_http.cpp	1085
2020-03-08 20:39:44	zmc_m4		13883	ERR	Unable to read header	zm_remote_camera_http.cpp
my 2 monitors are split between 2 storages now, one default(/var/lib/zoneminder/events) and second is a sshfs-directory
both work fine but none of these want to work with "download video", either tar or zip, export does export but omits the video in the exported zip file.
it plays fine from events but does not download correct..
I've searched the logs but cannot find any clues, no errors about exporting at all:
/var/log/zoneminder/zmc_m7.log:11:03/08/20 20:28:09.017324 zmc_m7[11828].ERR-zm_remote_camera_http.cpp/226 [Select error: Interrupted system call]
/var/log/zoneminder/zmc_m7.log:12:03/08/20 20:28:09.018091 zmc_m7[11828].ERR-zm_remote_camera_http.cpp/946 [Unable to read subheader]
/var/log/zoneminder/zmc_m7.log:13:03/08/20 20:28:09.018700 zmc_m7[11828].ERR-zm_remote_camera_http.cpp/1085 [Unable to get response, disconnecting]
/var/log/zoneminder/zmc_m7.log:18:03/08/20 20:28:23.629782 zmc_m7[11975].ERR-zm_remote_camera_http.cpp/226 [Select error: Interrupted system call]
/var/log/zoneminder/zmc_m7.log:19:03/08/20 20:28:23.630967 zmc_m7[11975].ERR-zm_remote_camera_http.cpp/946 [Unable to read subheader]
/var/log/zoneminder/zmc_m7.log:20:03/08/20 20:28:23.631771 zmc_m7[11975].ERR-zm_remote_camera_http.cpp/1085 [Unable to get response, disconnecting]
/var/log/zoneminder/zmc_m8.log:11:03/08/20 20:30:12.130808 zmc_m8[12251].ERR-zm_remote_camera_http.cpp/226 [Select error: Interrupted system call]
/var/log/zoneminder/zmc_m8.log:12:03/08/20 20:30:12.131713 zmc_m8[12251].ERR-zm_remote_camera_http.cpp/946 [Unable to read subheader]
/var/log/zoneminder/zmc_m8.log:13:03/08/20 20:30:12.132452 zmc_m8[12251].ERR-zm_remote_camera_http.cpp/1085 [Unable to get response, disconnecting]
/var/log/zoneminder/zma_m8.log:2:03/08/20 20:30:18.255092 zma_m8[12381].ERR-zm_monitor.cpp/574 [Got empty memory map file size 0, is the zmc process for this monitor running?]
/var/log/zoneminder/zms_e74.log:1:03/08/20 20:35:35.151787 zms_e74[13242].ERR-zm_eventstream.cpp/791 [Unable to send raw frame 8: Broken pipe]
/var/log/zoneminder/zms_e74.log:2:03/08/20 20:36:01.212295 zms_e74[13310].ERR-zm_eventstream.cpp/791 [Unable to send raw frame 1: Broken pipe]
/var/log/zoneminder/zms_e76.log:1:03/08/20 20:47:30.858508 zms_e76[15050].ERR-zm_eventstream.cpp/791 [Unable to send raw frame 1: Broken pipe]
/var/log/zoneminder/zms_e76.log:2:03/08/20 20:47:33.786010 zms_e76[15057].ERR-zm_eventstream.cpp/791 [Unable to send raw frame 7: Broken pipe]
/var/log/zoneminder/zms_e76.log:3:03/08/20 20:47:41.302128 zms_e76[15062].ERR-zm_eventstream.cpp/791 [Unable to send raw frame 157: Broken pipe]
WARNINGS:
/var/log/zoneminder/zmc_m4.log:1474:03/08/20 20:20:47.445413 zmc_m4[11142].WAR-zm_remote_camera_http.cpp/1081 [Unable to capture image, retrying]
/var/log/zoneminder/zmc_m4.log:1572:03/08/20 20:39:39.833239 zmc_m4[13883].WAR-zm_remote_camera_http.cpp/1081 [Unable to capture image, retrying]
Would you please elaborate on where to look for the logging for export/download.
And guys, thanks for the wonderfull work you're doing!
Adding recent .FAT logs. Again, I do not have monitor with id 6:
/var/log/zoneminder/zmcontrol_6.log:25:03/08/2020 20:50:49.382876 zmcontrol_6[15528].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:26:03/08/2020 20:50:54.580440 zmcontrol_6[15542].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:27:03/08/2020 20:51:04.809261 zmcontrol_6[15566].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:28:03/08/2020 20:51:25.036589 zmcontrol_6[15616].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:29:03/08/2020 20:52:05.297872 zmcontrol_6[15716].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:30:03/08/2020 20:53:25.613249 zmcontrol_6[15906].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:31:03/08/2020 20:56:06.023323 zmcontrol_6[16288].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:32:03/08/2020 21:01:26.900594 zmcontrol_6[17121].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:33:03/08/2020 21:11:27.056254 zmcontrol_6[18581].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:34:03/08/2020 21:21:28.171976 zmcontrol_6[20055].FAT [main:108] [Unable to load control data for monitor 6]
/var/log/zoneminder/zmcontrol_6.log:35:03/08/2020 21:31:28.233269 zmcontrol_6[21523].FAT [main:108] [Unable to load control data for monitor 6]
edgararroyo
Post by edgararroyo »
Export works fine for me, problem I am having is with the html viewer, the iframe height is not set correctly. I have to manually change "height: 100%;" to "height: 850px;" on the TD's style, usually 130px more than the video height (720) and add "height: 100%;" to the iframe's style.
For now, I have been adding on the <script> section:
$(document).ready(function() { $('#myframe').parent().css("height", "850px"); $('#myframe').css("height", "100%"); } );
And playback is awful slow, I need to scroll through manually to see it. Still haven't played around with the speed yet...
Is this being looked at?
Thanks!
No it isn't.
We look forward to your pr.
