Filter events longer than certain time. ZM 1.30.04
kamkaran
Re: Filter events longer than certain time. ZM 1.30.04
Post by kamkaran »
Try using lower case sec as much as you can.
Graduated from Soran University with First Class Degree with Honours in Computer Science.
Viher
Post by Viher »
Unable to go anywhere with this, I'll put this on hold for time being. I changed it to delete events with low score, seems to be working.
derbydog
Post by derbydog »
I just found this old thread trying to do the same thing. Looks like the duration is recorded in seconds. So to filter any events with a duration of 6 seconds you simply use the number 6 for duration.
