zm_detect.py error when testing zm_event_start.sh
Anyone seen an error like this one before and got around it?
I'm working in a freenas jail with zoneminder 1.32.3 with apache.
Had some trouble getting the API running but I've fixed that now I did have to edit ZMLog.py to get this far as it was complaining that my zm.conf couldn't be found in /etc/zm/zm.conf (it's at /usr/local/etc/zm.conf)
I'm wondering if there's more edits to these files that need to be made, but I would have thought it should be picking this up from config files somewhere else?
Thanks for any help!
Re: zm_detect.py error when testing zm_event_start.sh
when the zm_event_start.sh is triggered by the event server this is what I'm getting in the logs..
2020-03-18 15:58:50 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 hook end returned with text: json:[] exit:127 zmeventnotification.pl
2020-03-18 15:58:49 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Invoking hook on event end:'/usr/local/lib/zmeventnotification/bin/zm_event_end.sh' 467 1 "Front Garden" "Motion: New" zmeventnotification.pl
2020-03-18 15:58:47 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Event 467 for Monitor 1 has finished zmeventnotification.pl
2020-03-18 15:58:47 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Not sending over MQTT as notify filters are on_success:all and on_fail:none zmeventnotification.pl
2020-03-18 15:58:47 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Monitor 1 event: should send out as 4.13035988807678 is >= interval of zmeventnotification.pl
2020-03-18 15:58:47 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Checking alarm rules for MQTT 127.0.0.1 zmeventnotification.pl
2020-03-18 15:58:47 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Matching alarm to connection rules... zmeventnotification.pl
2020-03-18 15:58:46 zmeventnotification 77481 INF |----> FORK:Front Garden (1), eid:466 Not sending event end alarm, as we did not send a start alarm for this, or start hook processing failed zmeventnotification.pl
2020-03-18 15:58:45 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 hook start returned with text: json:[] exit:127 zmeventnotification.pl
2020-03-18 15:58:45 zmeventnotification 77501 INF |----> FORK:Front Garden (1), eid:467 Invoking hook on event start:'/usr/local/lib/zmeventnotification/bin/zm_event_start.sh' 467 1 "Front Garden" "Motion New" zmeventnotification.pl
2020-03-18 15:58:45 zmeventnotification 77501 INF PARENT: Forked process:77501 to handle alarm eid:467 zmeventnotification.pl
2020-03-18 15:58:45 zmeventnotification 77137 INF PARENT: There are 1 new Events to process zmeventnotification.pl
2020-03-18 15:58:45 zmeventnotification 77137 INF PARENT: New event 467 reported for Monitor:1 (Name:Front Garden) Motion New zmeventnotification.pl
2020-03-18 15:58:45 zmeventnotification 77137 INF PARENT: There are 1 active child forks... zmeventnotification.pl
You can't pass --config to zm_event_start.sh.
That is a parameter for zmdetect.py
If you are invoking zm_event_start.sh, edit that file and change CONFIG_FILE
With respect to logging, that is correct, by default it assumes "/etc/zm". You can change zm_detect.py "log.init" statements to override the conf_path https://github.com/pliablepixels/pyzm/b ... Log.py#L71
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
thanks!
I've got logpath overridden to /var/log/zm in the args and conf_path changed to /usr/local/etc already but it still seemed to be having an issue with ZM_PATH_LOGS as if it's not defined or something.
Then I noticed the line
for f in glob.glob(config['conf_path']+'/conf.d/*.conf'):
realised it wasn't picking up my extra config files so changed that to
for f in glob.glob(config['conf_path']+'/zoneminder/*.conf'):
Which has moved things along a bit although now I'm getting this;
File "/usr/local/lib/python3.7/site-packages/pyzm/ZMLog.py", in line 162 in init config_table = meta.tables[Config]
KeyError: 'Config'
looking at the code it definitely looks like that's getting defined though.
Thanks so much for the help!
KeyError: 'Config'
In ZMLogs.py I had to change;
config_table = meta.tables['Config']
log_table = meta.tables['Logs']
To
config_table = meta.tables['config']
log_table = meta.tables['logs']
no errors now and nothing returned in the console... which I guess is correct behaviour? No boxes around people in zmninja desktop yet but I'm guessing I just need to mess around with objectconfig.ini to get that working next.
Although please let me know if you think doing this might have messed something up somewhere
To
Actually, I'm still getting
eid:919 hook start returned with text: json:[] exit:127
In the zoneminder logs... which looks like it's a problem
exit 127 may mean the script is not found. Check if the paths are correct. Your screenshot shows /usr/local/lib/zmeventnotification. By default, the script configs use /var/lib/zmeventnotification
Out of curiosity: who maintains this ZM port and why are all paths/DB names different? Is it because of platform requirements?
Some other thoughts:
1. Are you really sure your tables are called 'config' and 'logs' and not 'Config' and 'Logs' in your zm DB? Can you connect to the DB and check?
2. When trying to track down issues, don't just rely on console output. Enable debug logs and inspect them. This entry has instructions on how to setup debugging https://zmeventnotification.readthedocs ... g-problems
ES docs
zmNinja docs
ES docs
zmNinja docs
Actually, I'm not sure who maintains it... it's the default package in a freenas jail when running pkg install zoneminder. Although I'm starting to wish I'd built it from source now with the problems it's caused me.
It seems like I might just have got all of my paths sorted now and it looks like those table names are right.
Although testing zm_direct.py still isn't playing nice. When I'm running that directly with the --config and --eventid I'm now getting a
"AttributeError: module 'cv2.dnn' has no attribute 'readNet'
I built this port of opencv with the contrib modules;
https://www.freshports.org/graphics/opencv
but I've seen it's v3.4.1 and I can't find a more up to date port so if that error is down to the version then I think I might just be blocked here?
Yup, you need 4.x to get the DNN functions. You could try building open cv from source.
ES docs
zmNinja docs
ES docs
zmNinja docs
On what cpu/hardware do you run freenas? I'm planning to run opencv on an i5-2500 (without gpu) but i'm not sure if it will be usable at all.
I'm on an i3-6100, so far performance has been totally fine with zoneminder. I'm struggling to get opencv-4.x.x to build from source though so no idea what that'll be like for performance yet. I'll let you know when/if I make it.
Also, I'd LOVE to hear about your install of opencv-4 if you can do it!
Thanks.
Thanks.
I did not do anything special.
After downloading both opencv, opencv_contrib and creating a build directory inside opencv as the official instructions say, this was my make script:
Note that the ARCH_BIN/CUDA/CUDNN was enabled because I wanted it to work with my GPU
# Important get your ARCH_BIN value from https://developer.nvidia.com/cuda-gpus#compute
# If you don't do this, when you use CUDA with openCV it will error out with 'make_policy' related
# errors
ARCH_BIN=6.1
cmake -D CMAKE_BUILD_TYPE=RELEASE \
-D INSTALL_PYTHON_EXAMPLES=ON \
-D INSTALL_C_EXAMPLES=OFF \
-D OPENCV_ENABLE_NONFREE=ON \
-D WITH_CUDA=ON \
-D WITH_CUDNN=ON \
-D OPENCV_DNN_CUDA=ON \
-D ENABLE_FAST_MATH=1 \
-D CUDA_FAST_MATH=1 \
-D CUDA_ARCH_BIN=${ARCH_BIN} \
-D WITH_CUBLAS=1 \
-D OPENCV_EXTRA_MODULES_PATH=/home/pp/fiddle/opencv/opencv_contrib/modules \
-D HAVE_opencv_python3=ON \
-D PYTHON_EXECUTABLE=/usr/bin/python3 \
-D BUILD_EXAMPLES=ON ..
ES docs
zmNinja docs
ES docs
zmNinja docs
hmm... if object detection relies on opencv-4.x I think I'm boned. Doesn't seem to be anything on google where someone has said they've got it working.
I've got through a number of different make errors so far but am hitting a wall at some references to 'memalign'
I'll keep trying but I think I might just have to wait until someone ports it properly or I switch to ubuntu. If I manage to get it going I'll post my method back here.
Let me know if you hear of anyone with object detection on freenas. And thanks so much for the help so far, it's been great and it's certainly boosted my troubleshooting skills.
Cheers,
Jon
Cheers,
Jon
Actually, i had no issues compiling opencv 4.3.0pre (master). I didn't compile the contrib packages or any optional dependencies (png, tiff, python...) though. I haven't deployed it to the target machine yet though.
git clone https://github.com/opencv/opencv.git
mkdir build && cd build
cmake -D CMAKE_BUILD_TYPE=Release ..
make -j3
make install
Ah... I may be wrong, but based on the zmes documentation I think contrib is required.
I'm making progress with the compile though... I've had to change a few things, switching malloc.h to stdlib.h, getting rid of a process to discover number of online processors and changing memalign. I'm up to about 75%
