Getting Many Issues upgrading from 1.33.8 to 1.34.6 or 1.35.1
seven
Post by seven »
I've been holding off upgrades for some time now due to these issues.
Upgrading from 1.33.8~20190510143016 to either
1.34.6
or
1.35.1~20200310184748
from iconnor ppa for xenial
Appears to only occur on one Cam, both are Onif IP cam's but cam 2 appears to crash, while cam 3 appears to be fine... (there is no cam 1),
2020-03-20 22:06:34.356174 zmc_m3[20992].WAR-zm_ffmpeg_camera.cpp/951 [ImageBufferCount 20 is too small. Needs to be at least 31. Either increase it or decrease time between keyframes]
2020-03-20 22:06:34.300550 zmdc[20943].INF-zmdc.pl ['zmc -m 2' starting at 20/03/20 22:06:34, pid = 24113]
2020-03-20 22:06:34.300550 zmdc[24113].INF-zmdc.pl ['zmc -m 2' started at 20/03/20 22:06:34]
2020-03-20 22:06:34.253980 zmdc[20943].INF-zmdc.pl [Starting pending process, zmc -m 2]
2020-03-20 22:06:33.640004 zmc_m3[20992].INF-zm_monitor.cpp/2546 [House Rear: images:7100 - Capturing at 14.29 fps, capturing bandwidth 63936bytes/sec]
2020-03-20 22:06:33.223570 zmdc[20943].INF-zmdc.pl ['zmc -m 2' crashed, signal 8]
2020-03-20 22:06:33.164800 zmdc[20943].WAR-zmdc.pl ['zmc -m 2' has not stopped at 20/03/20 22:06:33 after 60 seconds. Sending KILL to pid 23787]
2020-03-20 22:06:32.366506 zmc_m3[20992].WAR-zm_ffmpeg_camera.cpp/951 [ImageBufferCount 20 is too small. Needs to be at least 31. Either increase it or decrease time between keyframes]
2020-03-20 22:06:30.356112 zmc_m3[20992].WAR-zm_ffmpeg_camera.cpp/951 [ImageBufferCount 20 is too small. Needs to be at least 31. Either increase it or decrease time between keyframes]
2020-03-20 22:06:29.383420 zma_m3[20999].INF-zm_monitor.cpp/1297 [House Rear: 6400 - Analysing at 14.29 fps]
2020-03-20 22:06:28.356137 zmc_m3[20992].WAR-zm_ffmpeg_camera.cpp/951 [ImageBufferCount 20 is too small. Needs to be at least 31. Either increase it or decrease time between keyframes]
2020-03-20 22:06:26.959560 zmc_m3[20992].INF-zm_monitor.cpp/2546 [House Rear: images:7000 - Capturing at 16.67 fps, capturing bandwidth 113930bytes/sec]
2020-03-20 22:06:26.902540 zmdc[24095].INF-zmdc.pl ['zma -m 2' started at 20/03/20 22:06:26]
2020-03-20 22:06:26.901190 zmdc[20943].INF-zmdc.pl ['zma -m 2' starting at 20/03/20 22:06:26, pid = 24095]
2020-03-20 22:06:26.710290 zmdc[20943].INF-zmdc.pl ['zmc -m 2' sending stop to pid 23787 at 20/03/20 22:06:26]
2020-03-20 22:06:26.569310 zmdc[20943].INF-zmdc.pl ['zma -m 2' exited, signal 14]
2020-03-20 22:06:26.538770 zmdc[20943].INF-zmdc.pl ['zma -m 2' sending stop to pid 24044 at 20/03/20 22:06:26]
seven
Re: Getting Many Issues upgrading from 1.33.8 to 1.34.6 or 1.35.1
Post by seven »
I get similar logs in 1.33.8 but camera is online and functioning, camera is offline in the other versions or constantly alarming with errors "Reacquiring Signal"
2020-03-20 22:29:50.414694 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:50.360573 zma_m3[25432].INF-zm_monitor.cpp/1269 [House Rear: 6000 - Analysing at 12.50 fps]
2020-03-20 22:29:50.329562 zmc_m3[25616].WAR-zm_ffmpeg.cpp/64 [Invalid UE golomb code
2020-03-20 22:29:50.295707 zmc_m3[25427].WAR-zm_ffmpeg_camera.cpp/884 [ImageBufferCount 20 is too small.  Needs to be at least 61. Either increase it or decrease time between keyframes]
2020-03-20 22:29:50.262115 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Invalid UE golomb code
2020-03-20 22:29:50.228197 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:50.114280 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:49.986365 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:49.867239 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:49.764549 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:49.627819 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:49.514700 zmc_m3[25427].WAR-zm_ffmpeg.cpp/64 [Error parsing AU headers
2020-03-20 22:29:49.467572 zma_m2[25423].INF-zm_monitor.cpp/1635 [House Front: 4411 - Gone into prealarm state]
2020-03-20 22:29:49.441495 zma_m2[25423].WAR-zm_monitor.cpp/1392 [Signal: Reacquired]
Please enable debug logs
seven
Post by seven »
OK I think I've enabled debug logs but can see anything that sheds any light to me anyway, perhaps these are ffmpeg errors causing issues with Monitor 2.....
2020-03-25 20:53:00.191177 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:53:00.163417 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:53:00.112870 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:53:00.087741 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [mmco: unref short failure]
2020-03-25 20:53:00.055898 zmc_m3[10369].WAR-zm_ffmpeg.cpp/70 [Error parsing AU headers]
2020-03-25 20:53:00.020042 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:52:59.988842 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.953186 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [mmco: unref short failure]
2020-03-25 20:52:59.919134 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.885394 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:52:59.853892 zmc_m3[10369].WAR-zm_ffmpeg.cpp/70 [Error parsing AU headers]
2020-03-25 20:52:59.818445 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [mmco: unref short failure]
2020-03-25 20:52:59.784403 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.750614 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:52:59.719176 zmc_m3[10369].WAR-zm_ffmpeg.cpp/70 [Error parsing AU headers]
2020-03-25 20:52:59.683550 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [mmco: unref short failure]
2020-03-25 20:52:59.652134 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.615920 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:52:59.582378 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.548887 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [mmco: unref short failure]
2020-03-25 20:52:59.517008 zmc_m3[10369].WAR-zm_ffmpeg.cpp/70 [Error parsing AU headers]
2020-03-25 20:52:59.471891 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:52:59.448674 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.422868 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [mmco: unref short failure]
2020-03-25 20:52:59.406456 zma_m2[10622].DB1-zm_monitor.cpp/531 [Waiting for capture daemon last_write_index(101), last_write_time(0)]
2020-03-25 20:52:59.387562 zmc_m3[10369].DB1-zm_ffmpeg_camera.cpp/981 [raw frame from decoder: format 12 yuvj420p 1920x1080 linesize:1920x960 pts: -9223372036854775808]
2020-03-25 20:52:59.167358 zmc_m2[10527].WAR-zm_ffmpeg.cpp/70 [illegal short term buffer state detected]
2020-03-25 20:52:59.135846 zmc_m3[10369].WAR-zm_ffmpeg.cpp/70 [Error parsing AU headers]
seven
Post by seven »
some time ago I was running on Master releases due to some features I was after, but have not been able to upgrade since 1.33.8~20190510143016-xenial, first failed Update was 1.33.15~20191213181247-xenial & 1.33.16~20200113170925-xenial
Now on 1.35.1~20200310184748-xenial but seeing the same issues in 1.34.6-xenial1
I havn't seen those errors before.
Do you have values in your MaxFPS or AlarmMAXFPS fields? If so, please clear them.
seven
Post by seven »
Nope Neither Monitor has those settings set.
seven
Post by seven »
Interestingly I see similar logs in 1.33.8 so perhaps not related
I'm not entirely sure I enabled debug logging correctly is there some guide?
Your debug is fine. I just don't know what the problem is. ffmpeg is complaining about the stream. How are these cameras connected, ethernet or wifi?
seven
Post by seven »
Ethernet
Have you tried your system on Bionic?
seven
Post by seven »
bbunge wrote: Thu Mar 26, 2020 11:52 am Have you tried your system on Bionic?
Why would that work? does zoneminder use the system installed ffmpeg?
or its own internally forked version from upstream code?
We use the system ffmpeg libraries.
seven
Post by seven »
No worries, I'll might try running the upgrade in a docker container then.
seven
Post by seven »
Still Seeing similar issues in docker zm 1.34.6 using the 18.04 (very similar to what was seen in xenial)
I've also tried replacing /usr/bin/ffmpeg with the snapd ffmpeg package and no change in 1.33.8 I'll try again in 1.34.6 with the snapd ffmpeg
/usr/bin/ffmpeg -version
ffmpeg version 2.8.15-0ubuntu0.16.04.1 Copyright (c) 2000-2018 the FFmpeg developers
built with gcc 5.4.0 (Ubuntu 5.4.0-6ubuntu1~16.04.10) 20160609
configuration: --prefix=/usr --extra-version=0ubuntu0.16.04.1 --build-suffix=-ffmpeg --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --cc=cc --cxx=g++ --enable-gpl --enable-shared --disable-stripping --disable-decoder=libopenjpeg --disable-decoder=libschroedinger --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-librtmp --enable-libschroedinger --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxvid --enable-libzvbi --enable-openal --enable-opengl --enable-x11grab --enable-libdc1394 --enable-libiec61883 --enable-libzmq --enable-frei0r --enable-libx264 --enable-libopencv
libavutil      54. 31.100 / 54. 31.100
libavcodec     56. 60.100 / 56. 60.100
libavformat    56. 40.101 / 56. 40.101
libavdevice    56.  4.100 / 56.  4.100
libavfilter     5. 40.101 /  5. 40.101
libavresample   2.  1.  0 /  2.  1.  0
libswscale      3.  1.101 /  3.  1.101
libswresample   1.  2.101 /  1.  2.101
libpostproc    53.  3.100 / 53.  3.100
verses snapd ffmpeg
/snap/bin/ffmpeg -version
ffmpeg version n4.1.4 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 7 (Ubuntu 7.4.0-1ubuntu1~18.04.1)
configuration: --prefix= --prefix=/usr --disable-debug --disable-doc --disable-static --enable-avisynth --enable-cuda --enable-cuvid --enable-libdrm --enable-ffplay --enable-gnutls --enable-gpl --enable-libass --enable-libfdk-aac --enable-libfontconfig --enable-libfreetype --enable-libmp3lame --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libopus --enable-libpulse --enable-sdl2 --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libv4l2 --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libxcb --enable-libxvid --enable-nonfree --enable-nvenc --enable-omx --enable-openal --enable-opencl --enable-runtime-cpudetect --enable-shared --enable-vaapi --enable-vdpau --enable-version3 --enable-xlib
libavutil      56. 22.100 / 56. 22.100
libavcodec     58. 35.100 / 58. 35.100
libavformat    58. 20.100 / 58. 20.100
libavdevice    58.  5.100 / 58.  5.100
libavfilter     7. 40.101 /  7. 40.101
libswscale      5.  3.100 /  5.  3.100
libswresample   3.  3.100 /  3.  3.100
libpostproc    55.  3.100 / 55.  3.100
