I updated iOS on my iPhone then arrived an zmninja update and updated it too.
After this updates I didn't find my server in app (the configured servers are gone) and I can't setup it because can't be saved (nothing happens).
What happened?
Thank for your help.
zmninja iOS 13.4 update
Re: zmninja iOS 13.4 update
I'm not sure - I've started the update process to 13.4 to see if the new OS broke anything. Will update here.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
I just updated to iOS 13.4.1 and had no issues.
Do the following:
a) In zmNinja, clear API cache (Menu)
b) Exit the app
c) Go to ZoneMinder, to Options->API and click "Revoke all tokens"
d) Then run zmNinja
If you don't see your server, run Wizard (in my case, none of my settings were removed)
Do the following:
b) Exit the app
d) Then run zmNinja
ES docs
zmNinja docs
ES docs
zmNinja docs
thank you for your quickly answer but in the meantime, i upgraded to iOS 13.4.1 and nothing changed.
My server settings are gone and I can't create a new one. Unable to save server settings ... I click Save, but nothing happens. The configured server is not listed.
Thank you for your help.
Okay, try this:
1) Start zmNinja, go to settings, disable "Cloud backup", save
2) Exit app
3) Delete app from device
4) Install again
5) Use wizard
2) Exit app
4) Install again
5) Use wizard
ES docs
zmNinja docs
ES docs
zmNinja docs
thank you for your help, problem is solved.
Your advice for reinstall was successful.
Thank you for very quickly help and solution. Many thanks.
Kind Regards
Kind Regards
Sounds good!
ES docs
zmNinja docs
ES docs
zmNinja docs
