Hello to all,
I've purchased two BESDER PTZ CAMs:
https://www.aliexpress.com/item/3303835 ... 4c4d69ZdPx
I'm testing it succesfully using the "OnVIF Device Manager 2.2.250". I can see thise CAM informations:
Manifacturer: H264
Model: XM530_80X20_8M
Firmware: V5.00.R02.00030678.10010.244500..ONVIF 2.41
ONVIF Version: 2.41
With this App I'm able to see live stream, use PTZ and Zoom.
Now, I'm trying to add it to Zoneminder. The Onvif discover works, and the stream too. BTW I've no idea how let the PTZ and Zoom work on Zoneminder.
I've tested the ONVIF profile and netcat ONVIF, but no luck.
With the ONVIF program under Windows it works well.
Can someone help me?
Thanks!
Simon
Helo configuring XM530 BESDER
Re: Helo configuring XM530 BESDER
hi,
i use with XM530 hisilicon (similar CAM)
test it
test it
- ptz.jpg (65.57 KiB) Viewed 6438 times
Hello!
I've no idea why but leaving as Control Device the default or putting '000' the value was not used/taken, so I've copied the Netcat.pm to a custom one and added the control_device to '000', otherwise it was starting with something similar to 'onvif/device_list'.
BTW in that way it works, so it's similar to your settings.
Thanks a lot for the support!
Simon
Simon
