zmNinja exit full montage view
gregthegeek
Post by gregthegeek »
Hello all!
New to ZoneMinder, just got server working. Now I'm playing with zmNinja on MacOS and the very first thing I did was view montage and click the little cross-plus-whatever that icon is that opens full view (not full screen kiosk) of the montage with no tool bars. I can't find any way out of it!! ?? Is there a a keyboard short cut or hidden button?
thank you for your help!
gregthegeek
Re: zmNinja exit full montage view
Never mind! I got out!
I discovered dragging the mouse to the right shows the menu, and then in developer settings I added extended info on montage and when I went back it showed me a toolbar finally. Then I disabled all the extended info and its normal. I just won't touch that crosshair/reticle button until I know how to exit the full view. If anyone knows the trick for that I'd like to know.
Try Ctrl-Shift-F to toggle fullscreen mode ON or OFF.
