CentOS 8 cannot install zoneminder
Crazyjpeters
Re: CentOS 8 cannot install zoneminder
Post by Crazyjpeters »
I'm in the same boat. I'm trying to use NGINX. I can follow the installation instructions up until I get to start NGINX, and I get errors. This has got to be the most clunky software I've ever tried to install...
ZM 1.36
Ubuntu 22.04 LTS / NGINX
ESXi 6.7 VM
xfr
Post by xfr »
allanhitch wrote: Wed Apr 15, 2020 12:07 am I'm lost.....
I can't get it to install
I realize that this is a bit old, but I tried and got it installed on Centos8 by doing:
dnf config-manager --set-enabled PowerTools
dnf install zoneminder
credulous11
Post by credulous11 »
@knight-of-ni works perfectly when I enable PowerTools.
Thanks for the headsup.
Echemenon
Post by Echemenon »
I enabled power tools using this: https://andrewsarver.com/enable-centos- ... ools-repo/
then "sudo yum install perl-DateTime"
then was able to "sudo yum install zoneminder" and it all went according to plan
Centaurus17
Post by Centaurus17 »
Hi
I was happy to find this thread and the previous posting ... I enabled the PowerTools, I installed 'perl-DateTime' ...
... then was able to "sudo yum install zoneminder" and it all went according to plan
... not here: (I translate from German): "Last check for expired metadata Fri 30 Oct No match for argument zoneminder"
??? Please help step by step to install zm on a new Centos 8 system (me=rookie)
Thx
Centaurus17
I'm overstrained ... should I download 'https://mirrors.rpmfusion.org/free/el/r ... noarch.rpm' - and then?
Yes, you download and install it. That adds the repo to your system. Then you can install any software that the new repo knows about.
