Unable to open input rtsp://admin:xxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp due to: Invalid data
TheRoth
Post by TheRoth »
I'm new here, i'm french and it's my first message here :)
So, i have a 9 camera and 7 work well... 2 not capturing. (it's a different model). My ZoneMinder is on MacMini Server (old generation, middle 2012) On last Debian Buster 5.4.0-4-amd64 #1 SMP Debian 5.4.19-1 (2020-02-13) x86_64
The camera model is S5-T, buy from Ali, is a very cheap camera ^^ Only Wifi. in H264
i Have this message in the journal
Unable to open input rtsp://admin:xxxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp due to: Invalid data found when processing input
Failed to prime capture of initial monitor
If i try on VLC, it work well, no error ...
VLC
VLC
Screenshot 2020-05-05 at 06.12.09.png (78.5 KiB) Viewed 10024 times
I try to change UDP/TCP, Resolution, etc... What can i do ?
Thanks for your messages
Re: Unable to open input rtsp://admin:xxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp due to: Invalid data
a mac mini....
9 cameras..
I'm suspecting out of ram or cpu....
we will need proper debug logs.
TheRoth
Post by TheRoth »
Hi Iconnor,
i disabled all camera, to see, if it was a problem of ram... And, same problem...
Screenshot 2020-05-06 at 07.19.11.png (14.45 KiB) Viewed 9981 times
The Log
Date/Heure
Composant Server PID Niveau Message Fichier Ligne
2020-05-06 05:21:31 zmc_m9 722464 INF Priming capture from rtsp://admin:@10.15.67.149:554/realmonitor?channel=0&stream=0.sdp zm_ffmpeg_camera.cpp 201
2020-05-06 05:21:31 zmc_m9 722464 ERR Unable to open input rtsp://admin:@10.15.67.149:554/realmonitor?channel=0&stream=0.sdp due to: Invalid data found when processing input zm_ffmpeg_camera.cpp 379
2020-05-06 05:21:31 zmc_m9 722464 ERR Failed to prime capture of initial monitor zmc.cpp 257
2020-05-06 05:21:21 zmc_m9 722464 INF Priming capture from rtsp://admin:@10.15.67.149:554/realmonitor?channel=0&stream=0.sdp zm_ffmpeg_camera.cpp 201
2020-05-06 05:21:21 zmc_m9 722464 ERR Unable to open input rtsp://admin:@10.15.67.149:554/realmonitor?channel=0&stream=0.sdp due to: Invalid data found when processing input zm_ffmpeg_camera.cpp 379
2020-05-06 05:21:21 zmc_m9 722464 ERR Failed to prime capture of initial monitor zmc.cpp 257
2020-05-06 05:21:11 zmc_m9 722464 INF Priming capture from rtsp://admin:@10.15.67.149:554/realmonitor?channel=0&stream=0.sdp
Not to but in, but when I've had that it means the login failed.
Sometimes a stray character in string.
Can you (or did you) copy/paste from the vlc string?
snake
Post by snake »
https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
Either the path is wrong, or the camera is incompatible w/ZM. You can try different source methods (ffmpeg, vlc, remote, file, etc). As an example, if the camera can upload images to an FTP server, then you can use source: file and host the FTP server locally on the camera server.
TheRoth
Post by TheRoth »
Hi DougMcCrary and Snake,
Yes, i copy/paste the link directly to VLC and it's work... With the code.. Same Problem.
Snake, i will check with your link...
TheRoth
Post by TheRoth »
This is Snake Suggestion :)
I try directly on ffmpeg with debug level...
Error : rtsp://admin:xxxxxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp: Invalid data found when processing input
The Full log:
root@server:~# ffmpeg -i "rtsp://admin:xxxxxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp" -loglevel debug output.mp4
ffmpeg version 4.2.2-1+b1 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 9 (Debian 9.2.1-28)
configuration: --prefix=/usr --extra-version=1+b1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libavresample 4. 0. 0 / 4. 0. 0
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
Splitting the commandline.
Reading option '-i' ... matched as input url with argument 'rtsp://admin:xxxxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp'.
Reading option '-loglevel' ... matched as option 'loglevel' (set logging level) with argument 'debug'.
Reading option 'output.mp4' ... matched as output url.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option loglevel (set logging level) with argument debug.
Successfully parsed a group of options.
Parsing a group of options: input url rtsp://admin:xxxxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp.
Opening an input file: rtsp://admin:xxxxxx@10.15.67.148:554/realmonitor?channel=0&stream=0.sdp.
[tcp @ 0x5626eb03b400] No default whitelist set
[tcp @ 0x5626eb03b400] Original list of addresses:
[tcp @ 0x5626eb03b400] Address 10.15.67.148 port 554
[tcp @ 0x5626eb03b400] Interleaved list of addresses:
[tcp @ 0x5626eb03b400] Starting connection attempt to 10.15.67.148 port 554
[tcp @ 0x5626eb03b400] Successfully connected to 10.15.67.148 port 554
[rtsp @ 0x5626eb039140] SDP:
v=0
o=- -79913188 -79913188 IN IP4 10.15.67.148
t=0 0
c=IN IP4 10.15.67.148
a=packetization-supported:Puwell
m=video 0 RTP/AVP 96
a=control:trackID=0
a=rtpmap:96 H264/90000
a=framerate:0S
a=fmtp:96 profile-level-id=4d401f; packetization-mode=1; sprop-parameter-sets=Z01AH52oFAFuhAAAAwAEAAADAHoQ,aO48gA==
m=audio 0 RTP/AVP 8
a=control:trackID=1
a=rtpmap:8 PCMA/8000
[rtsp @ 0x5626eb039140] video codec set to: h264
[rtsp @ 0x5626eb039140] RTP Profile IDC: 4d Profile IOP: 40 Level: 1f
[rtsp @ 0x5626eb039140] RTP Packetization Mode: 1
[rtsp @ 0x5626eb039140] Extradata set to 0x5626eb03c490 (size: 33)
[rtsp @ 0x5626eb039140] audio codec set to: pcm_alaw
[rtsp @ 0x5626eb039140] audio samplerate set to: 8000
[rtsp @ 0x5626eb039140] audio channels set to: 1
[rtp @ 0x5626eb03e780] No default whitelist set
[udp @ 0x5626eb03f280] No default whitelist set
[udp @ 0x5626eb03f280] end receive buffer size reported is 131072
[udp @ 0x5626eb03ee80] No default whitelist set
[udp @ 0x5626eb03ee80] end receive buffer size reported is 131072
root@HomeKit:~#
snake
Post by snake »
Try source type: libvlc. To install libvlc:
I think it is apt-get install libvlc-dev libvlccore-dev vlc
But possibly omitting vlc. Just try not to pull in X if its not required.
Restart zoneminder service after installing.
MachoMan
Post by MachoMan »
Hi Everybody
Sorry for my bad english !
I have been using ZM for over 12 years and have tried it in many dists. But now i feel for giving it up.. Why ??
It use to work in a clean VM or Standalone computer, but every time i run update everything crashes and back to square no 1 again.
I think i would be better to reorganize the people working with M, something must be wrong. I am using lots of software, but none has
been crashing in every update.
I was so happy to see how good 1.32 and up to 1.34 was working, the playback was working on every client both chrome, firefox and in mobile
no problem, but suddenly the new playback speed feature showed up, and pop... and all luck was gone !!!
You guys must slow down the speed of programming and start thinking of how can this be working on all devices and will it be backward compatible.
No playback fwd/rew is working for me now and export is working bad. Why isnt there any backup possiblety for settings and or data.
And why cant an old installation be overwritten and reconnecting to old data and database ?? And why isnt theres a possiblity to select stable/testing
releases in install or update ?? And why not using a testgroup before release ?? And my must i be afraid till install a new releases every time.
In release 1.32 up to 1.34 there were some small problem, but now it is impossible to use which i'am sorry to say.
For now i'am running on debian buster/vm
I have earlier been so happy to using ZM since iam not that rich and i have sending films to police in thefts, so it have helped me a lot.
And please move this post to the right place if iam wrong here.
Kind regards
Håkan
TheRoth
Post by TheRoth »
Thanks Snake :)
I think it's good idea ^^
So i try your solution, and i have another problem ...
The following packages have unmet dependencies:
vlc : Depends: vlc-plugin-video-output (= 3.0.10-0+deb10u1) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
i will come back when i will find a solution for this new problem ...
