V 1.34.11 on centos
The button to set Layout presets with 3,4,5 wide doesn't work any more under montage view.
skin classic dark
Montage, Layout, (3-wide etc) doesn't work any more
Re: Montage, Layout, (3-wide etc) doesn't work any more
found a semi workaround. select 3 wide, push edit layout, then cancel. now you get 3 wide..
still broken 1.34.16
classic dark
classic dark
