Sircam SP017 not working
giorgio.zarrelli
Post by giorgio.zarrelli »
i am new to ZoneMinder and I am trying to connect a Sircam SP017. I checked this thread viewtopic.php?f=10&t=27624&p=107605&hilit=sp017#p107605 but the infos look a bit outdated.
I created a monitor with a source type remote, then I specified:
Protocol: RTSP
Method: RTP/Unicast
Hostname: rtsp://my_ip
Port: 554
Path: onvif
Preset: 1080P
I tried to add admin:password to the hostname, but with or without I cannot get a connection. Interestingly, I tried Xeoma and using:
rtsp://my_ip/onvif
works fine. No user, no password (creepy), no port, I just got the video streaming working. So, the rtsp works, and does not even need any credentials, what is, in your opinion, preventing ZoneMinder from using the camera?
Thanks.
Re: Sircam SP017 not working
You probably need a / in the path => /onvif
In any event, use the ffmpeg input type and use the same url you used in Xeoma.
coleganet
Post by coleganet »
You need rtsp://192.168.1.17:554/onvif1
I have several Siricam good price specifically the SP007 with metal case. Resolution is up to your server is maximum 1280
Look the 2 attach files .
