Could not open out file: permission denied
Zipdox
Post by Zipdox »
I can't seem to be able to make zoneminder use an external drive. Despite having set the ownership and permissions of the directory correctly, it still fails.
Take a look at the attached images.
What am I missing?
mikb
Re: Could not open out file: permission denied
Post by mikb »
Need more information about the external drive -- most importantly, is it using a FAT filesystem, or a proper one like ext4? How is it connected (USB, network?) Model number etc. (so others can Google what you've got).
It is possible that the drive is using a FAT file system (which is pretty clueless about permissions and ownership -- no matter what Linux will try and show you) and worse still, doesn't understand symbolic links, which are used by ZoneMinder and a fundamental part of a real filesystem.
The permissions look a bit enthusiastic there - rwxrwxrwx means EVERYONE can look in there, create, edit, delete stuff, which is not great for security, so you may want to tighten that up later.
Zipdox
Post by Zipdox »
mikb wrote: Tue Jun 30, 2020 3:59 pm Need more information about the external drive -- most importantly, is it using a FAT filesystem, or a proper one like ext4? How is it connected (USB, network?) Model number etc. (so others can Google what you've got).
It's ext4. I chose the lackluster permissions to make sure that the permissions are not the problem. The disk is connected to motherboard SATA. Here's a parted dump:
Model: ATA WDC WD80PURZ-85Y (scsi)
Disk /dev/sdb: 8002GB
Sector size (logical/physical): 512B/4096B
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system  Flags
 1      0.00B  8002GB  8002GB  ext4
mikb
Post by mikb »
Ah, not what I was expecting!
ext4 is a proper file system. Good.
Direct SATA connection -- Good -- this rules out flaky USB enclosures and CIFS/SMB networking devices that don't know how to work properly.
The wide permissions being deliberate I can understand, please make sure to re-attach the doors and windows once you're done testing!
Do I understand correctly that /survaillance (directory ".." from your screenshot) is owned by "server, server" and is therefore only accessible to that user? Could this stop zoneminder traversing into /survaillance to get to the lower directories (zoneminder/events)?
Maybe /survaillance should be rwxr-xr-x (chmod 755) to let ZM look in there? Or try "rwx--x--x" (chmod 711) to let it go in but not look around?
the directories ownership needs to be the same as the web server and Zoneminder user. There are several that need to be the same.
Zipdox
Post by Zipdox »
mikb wrote: Thu Jul 02, 2020 3:29 pm Ah, not what I was expecting!
I will try that.
Zipdox
Post by Zipdox »
Yep that fixed it.
