Master on Ubuntu 20.04
DVB Hardware
Post by DVB Hardware »
I am on a test machine and for a whim I upgraded Mint 19.4 > 20.04 to see what happens.
Seems ZM is broken however Apache & MSQL are running
I checked the wiki nothing for 20.04 yet , the latest is 19.10
Cannot find any guidance for 20.04 in the forum
Jimmy
SteveGilvarry
Re: Master on Ubuntu 20.04
Post by SteveGilvarry »
Might have missed it as it doesn't list a version. I did this recently just changed ppa to master.
https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.34.x
DVB Hardware
Thanks Steve, it was hidden at the top of the wiki page
I did not have much luck with that script but I did find this one with some success
https://bkjaya.wordpress.com/2020/05/26 ... cal-fossa/
This one runs but no monitor to view (Not Green)
I know the camera works via vlc and web app and it was running ok master=1.35.5 on Linux mint 19.3
When I upgraded to 20.04 hence this problem using the same monitor configuration
I'm missing something
Attached jpg of errors, just keeps repeating
Thank You
Jimmy
error log.jpg (560.54 KiB) Viewed 9139 times
FWIW -
I did the same but on mysql, and it's working mostly fine.
I do one remote camera as in your http:; the rest are rstp:.
Looks like you have a buffer permissions problem.
SteveGilvarry
Maybe I will check Mint sometime but that script flies through on Ubuntu 20.04 and gives me a ready system. I do change ppa to zoneminder-master to get 1.35.
You got non h264 cameras I take it? I am not so good on them or the remote monitor side at all. But I think that is a mismatch in frame size what you have configured vs what camera is outputting. If that confirms OK turn on debug on _zmc_m1 level 9 and see what the debug file says.
DVB Hardware
Yes it is an older Panasonic BL-C131A that I use at home just for testing ZM
Funny part is it always worked flawlessly and on Mint 19.3 18.04 Bionic on ZM 1.35 before I changed to 20.04
I did wipe 1.35x and installed 1.34x only with the same problem
Gut feeling its a problem using 20.04 , possibly something missing, Mint based on Ubuntu kernal ??
I will check the log once I figure out to generate and find it...know some Linux not proficient
Jimmy
DVB Hardware
Still trying
Log (attached) seems the same as I posted if I have the correct one
Jimmy
zmc_m1.log
(95.5 KiB) Downloaded 472 times
DVB Hardware
GOT IT!!
Camera > Source > Path = "/nphMotionJpeg?Resolution=640x480&Quality=Standard
was imputing "nphMotionJpeg?Resolution=640x480&Quality=Standard"
I never backed up my monitors table since I only have one camera but I did have an older one that did not have "/" in the table. So I just exported the monitors table in 1.35 and it does have "/"
Jimmy
SteveGilvarry
Good to hear you found it.
I guess I'm missing something or the latest three or so packages are broken somehow.
I've done a fresh install of 1.34.x , and it's functional.
"Upgrade" to master, and it's broken. mysql password problem.
apt remove zoneminder (master) and apt install zoneminder (1.34) and it works again.
root@doug-System-zmx:/home/doug# zmupdate.pl
Initiating database upgrade to version 1.35.18 from version 1.34.23
Do you wish to take a backup of your database prior to upgrading?
This may result in a large file in /var/tmp/zm if you have a lot of events.
Press 'y' for a backup or 'n' to continue : n
Upgrading database to version 1.35.18
Loading config from DB 220 entries
Saving config to DB 220 entries
Upgrading DB to 1.35.0 from 1.34.23
mysql: [Warning] Using a password on the command line interface can be insecure.
Database successfully upgraded to version 1.35.0.
Upgrading DB to 1.35.1 from 1.34.23
Database successfully upgraded to version 1.35.1.
Upgrading DB to 1.35.2 from 1.34.23
Database successfully upgraded to version 1.35.2.
Upgrading DB to 1.35.3 from 1.34.23
Database successfully upgraded to version 1.35.3.
Upgrading DB to 1.35.4 from 1.34.23
Database successfully upgraded to version 1.35.4.
Upgrading DB to 1.35.5 from 1.34.23
Database successfully upgraded to version 1.35.5.
Upgrading DB to 1.35.6 from 1.34.23
Database successfully upgraded to version 1.35.6.
Upgrading DB to 1.35.7 from 1.34.23
Database successfully upgraded to version 1.35.7.
Upgrading DB to 1.35.8 from 1.34.23
Database successfully upgraded to version 1.35.8.
Upgrading DB to 1.35.9 from 1.34.23
Database successfully upgraded to version 1.35.9.
Upgrading DB to 1.35.10 from 1.34.23
Database successfully upgraded to version 1.35.10.
Upgrading DB to 1.35.11 from 1.34.23
Database successfully upgraded to version 1.35.11.
Upgrading DB to 1.35.12 from 1.34.23
Database successfully upgraded to version 1.35.12.
Upgrading DB to 1.35.13 from 1.34.23
ERROR 1419 (HY000) at line 83: You do not have the SUPER privilege and binary logging is enabled (you *might* want to use the less safe log_bin_trust_function_creators variable)
Output: Column StartDateTime already exists in Events
Column EndDateTime already exists in Events
Column StartDateTime already exists in Events_Hour
Column StartDateTime already exists in Events_Day
Column StartDateTime already exists in Events_Week
Column StartDateTime already exists in Events_Month
Command 'mysql -hlocalhost -uzmuser -p'zmpass' zm < /usr/share/zoneminder/db/zm_update-1.35.13.sql' exited with status: 1
Sometimes it's worth running the update command as a user with greater DB privileges.
Stay on 1.34 is the option if you prefer not to have to fiddle about.
Magic919 wrote: Thu Feb 11, 2021 11:11 am Sometimes it's worth running the update command as a user with greater DB privileges.
Thanks.
I don't know how to run "update command as a user with greater DB privileges."
That's a sudo su command line, and that
also happened during the install from the script at https://wiki.zoneminder.com/Ubuntu_Serv ... der_1.34.x, I believe.
I thought it should work given the note about mysql 8 on eoan - ubuntu 19.10.
BTW, I run two machines - one release on bionic w/1.34 and the one on focal w/1.35 I call zmx...You might say the one on 1.34 is backup.
I mostly use 1.35 when it works, cuz it's cool(er).
Ok. Maybe I needed to make that clearer.
This bit from your earlier post
Run that command, but pass it details of a MySQL superuser.
--user=<dbuser> - Alternate DB user with privileges to alter DB
    -p<dbpass>, --pass=<dbpass> - Password of alternate DB user with
OK. Better.
Thanks.
