If I am in the wrong place I apologize.
Zoneminder running in a docker on Unraid
I have many Onvif Chinese Cameras, all of them, but one has HTTP access to "IP Camera" and use the CamHi app.
I have a new one that does not have HTTP access and uses the Icsee app, if I go to the IP address on a pc it installs an app NetSurveillance WEB.
I want to get PTZ working in Zoneminder, but have not been able to figure this out.
For my CamHi cams, the source path that I use is rtsp://xxxxxx:xxxxxx@192.168.1.11:554/1
For my Icsee cam the source path that I use is rtsp://192.168.1.18:554/user=admin_password=6QNMIQGe_channel=1_stream=0.sdp?real_stream
Onvif device manager controls the PTZ on all of my PTZ cams.
The cameras controlled by Camhi respond to PTZ commands from CamHi, HTTP and OnvifDM
The cameras controlled by Icsee respond to PTZ commands from Icsee, HTTP and OnvifDM
Thanks for any help provided.
Chas
PTZ NoName Cameras
Re: PTZ NoName Cameras
Using these setting the CamHi PTZ camera and it moves but does not stop. I do not think the zoom works at all.
Control Source: Netcat ONVIF
Control Device: MainStream
Control Address: admin:admin@192.168.1.14:8080/onvif/ptz
And the Icsee cam won't move at all with these settings
Control Address: admin:admin@192.168.1.18:8899/onvif/device_service
Chas
Chas
You need to set the AUto Stop time.
Yes, thank you. I fought with this all day and found that it works if I have, continuously, absolute and Relative checked in the Netcat onvif control type.
With username:password@192.168.2.69:8080/onvif/ptz_service in the control address and MainStream in the control device for the CamHi cams
and
username:password@192.168.1.18:8899/onvif/ptz_service for the Icsee cams
The Zoom, and Focus seem to work as well.
and
