Rotated camera, montage and ZmNinja broken after upgrade
nrbell
Post by nrbell »
I just upgraded to 1.35.5~20200714143209-bionic and some things are broken. I can get video from most of my cameras, but my camera that is rotated 90 degrees shows mostly misplaced scan lines with an occasional flash of the non-rotated image.
The montage on the web interface and on ZmNinja is broken for all cameras. All monitors show some version of vertical stripes.
I was able to get back to normal by downgrading to 1.35.5~20200617125058-bionic.
Anyone else?
Screenshot from 2020-07-14 15-58-06.png (52.89 KiB) Viewed 3736 times
Screenshot from 2020-07-14 15-57-45.png (975.73 KiB) Viewed 3736 times
Re: Rotated camera, montage and ZmNinja broken after upgrade
On focal (20.04) it looks like a scaling problem.
At "Actual" looks OK. Anything else is like yours.
edit: not exactly like yours, but messed up vertical. Not like the fuzzy ones.
Interestingly, "scale to fit" is also OK.
fennec
Post by fennec »
Same bug on 18.04 after update 1.35.5 apt update
when scale active image strange
scale 100% is ok on zmninja but less than 100 bug
traveler21
Post by traveler21 »
Same problem here. Only the montage view has the lines, when I click on a camera the full screen looks fine, both on the web interface and on zmNinja. I may try the downgrade.
Traveler21, does "scale to fit" not look OK n your system? Which is what, BTW?
I see a new 1.35 That fixes the displays, for me.
