I get the following errors when I run make.
zm_mpeg.cpp:88: error: ‘struct AVCodecContext’ has no member named ‘frame_rate’
zm_mpeg.cpp:90: error: ‘struct AVCodecContext’ has no member named ‘frame_rate_base’
I used the following command to configure:
./configure --with-mysql=/usr --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/include/ffmpeg --with-lame=/usr/include/lame
I also tried without these two options -with-ffmpeg=/usr/include/ffmpeg --with-lame=/usr/include/lame,but I still get same errors.
I used following commands in following order:
./configure
perl ./zmconfig.p
perl ./zmconfig.pl -noi
make
environment:
zm-1.21.3
FC4 with updated to newest packages of (Sep 16)
Following packages installed
ffmpeg, ffmpeg-devel, lame, lame-devel
Am I missing any other packages?
or do I have to specify something different than default in "perl ./zmconfig.pl"?
Best Regards,
RMJ
I get an error on Make zm_mpeg.cpp:88: error:
- zoneminder
- Site Admin
- Contact:
