Upgraded from 1.34.16 to 1.34.18 no motion events
tcg
Re: Upgraded from 1.34.16 to 1.34.18 no motion events
Post by tcg »
Thanks for the Docker instructions!
Chris
systemd
Post by systemd »
iconnor wrote: Tue Aug 11, 2020 3:01 pm Okay I think I found it.
Tested 1.34.19, now it works for me again! Thanks!
tcg
Post by tcg »
1.34.19 fixed the problem for me as well Thank you Isaac!
Chris
drkananga
Post by drkananga »
Yes, 1.34.19 solved the issue!
Thanks!
w00tl00ps
Post by w00tl00ps »
Updated to 1.34.19 and it solved the issue for me too. Thank you so much for the quick update iconnor!
tagaroni
Post by tagaroni »
I updated on my Fedora system today and went to 1.34.18 (this is the latest version on RPM Fusion) and now suffer from this problem. How should I upgrade to 1.34.19 if it's not available via dnf update?
bigdigiman
Post by bigdigiman »
I too am only finding the 1.34.18 RPM on RPM Fusion and am in need of 1.34.19 as well...
