latest update Zoneminder master 1.35.5~20200816200911-focal test run
bkjaya1952
Post by bkjaya1952 »
I have tested the latest Zoneminder master 1.35.5~20200816200911-focal issued today with two cameras (, USB camera & Hikvision IP camera ).
1. monitor creation is ok
2. Motion detection events can be viewable . Video creation is OK.
3. E-mailing and uploading events can be done.
4. When you press settings button of the monitor ,the popup window shows camera settings (brightness etc) but still can not be adjusted . But this is not a major issue as the brightness settings can easly be adjusted externally using other software .
Found some useful and nice new menu arrangement .
Screenshot from 2020-08-17 10-50-00.png (245.67 KiB) Viewed 1215 times
Screenshot from 2020-08-17 10-52-59.png (315.13 KiB) Viewed 1215 times
Screenshot from 2020-08-17 11-39-25.png (101.72 KiB) Viewed 1215 times
Re: latest update Zoneminder master 1.35.5~20200816200911-focal test run
Couple things -
Events for a given came show the correct events, but the the events in event sequence, not per camera.
The event times and duration are not legible with dark CSS.
focal and bionic. No surprise.
