having issues getting hooks going
Re: having issues getting hooks going
Yes, correct. I've made that change.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Any thoughts as to why neither event_start_hook_notify_userscript or event_end_hook_notify_userscript are getting called. I double checked both scripts (I copied the example.py and renamed it and have the end userscript variable pointing to it) are owned by www-data and are executable. I also did a test run manually executing the script and it inserted the line into the log. Neither executed when motion was triggered by a camera. Thoughts?
Can't say without seeing zmeventnotification logs (with debug level enabled) on what happens when an applicable event triggers. My guess would be if hooks are on, no objects are detected.lorenjz wrote: ↑Fri Aug 21, 2020 2:52 am Any thoughts as to why neither event_start_hook_notify_userscript or event_end_hook_notify_userscript are getting called. I double checked both scripts (I copied the example.py and renamed it and have the end userscript variable pointing to it) are owned by www-data and are executable. I also did a test run manually executing the script and it inserted the line into the log. Neither executed when motion was triggered by a camera. Thoughts?
ES docs
zmNinja docs
ES docs
zmNinja docs
I had a little more time this morning to try and troubleshoot this. I can see where the logs say that they start example.py and lzhomeseer.py. Both scripts run without any errors when executed manually as the www-data user. example.py hasn't been changed. lzhomeseer.py is a copy of example.py with a few lines to send a push notification to my phone via pushover.
Attached is a log that I saved according to the guidance on the wiki page. It should contain all of event 10099 on monitor 12. Any help or insight that you could provide at your earliest convenience would certainly be appreciated. If I need to clarify any details or add more information I'm happy to do so. Again many thanks for all of your help and guidance!
Loren
Loren
- eid10099zmeventnotification.log
- (164.87 KiB) Downloaded 1002 times
I don't quite understand the issue. Both your event start and event end scripts are being called according to your logs.
Note however, this log:
I don't know what your script are doing, but summary:
a) They are being called
b) the ES itself is not sending a push as Monitor 12 is excluded (likely not selected in zmNinja)
08/30/2020 09:39:17.171694 zmeventnotification[9887].DBG [main:935] [|----> FORK:Small Room Sub (12), eid:10099 invoking user start notification script '/var/lib/zmeventnotification/contrib/example.py' 1 10099 12 "Small Room Sub" "" "[]" "/var/cache/zoneminder/events/12/2020-08-30/10099"]
08/30/2020 09:39:21.239339 zmeventnotification[9887].DBG [main:935] [|----> FORK:Small Room Sub (12), eid:10099 invoking user end notification script '/var/lib/zmeventnotification/contrib/lzHomeseer.py' 0 10099 12 "Small Room Sub" "Motion: All" "[]" "/var/cache/zoneminder/events/12/2020-08-30/10099"]
08/30/2020 09:39:19.219835 zmeventnotification[9887].DBG [main:935] [|----> FORK:Small Room Sub (12), eid:10099 should NOT send alarm as Monitor 12 is excluded]
ES docs
zmNinja docs
ES docs
zmNinja docs
There is an entry in the log that says they are being called. However zmeventnotification_userscript_example.log has no evidence that they are (aside from the two manual attempts that I made today). Thoughts?asker wrote: ↑Sun Aug 30, 2020 8:22 pm I don't quite understand the issue. Both your event start and event end scripts are being called according to your logs.Note however, this log:Code: Select all
08/30/2020 09:39:17.171694 zmeventnotification[9887].DBG [main:935] [|----> FORK:Small Room Sub (12), eid:10099 invoking user start notification script '/var/lib/zmeventnotification/contrib/example.py' 1 10099 12 "Small Room Sub" "" "[]" "/var/cache/zoneminder/events/12/2020-08-30/10099"] 08/30/2020 09:39:21.239339 zmeventnotification[9887].DBG [main:935] [|----> FORK:Small Room Sub (12), eid:10099 invoking user end notification script '/var/lib/zmeventnotification/contrib/lzHomeseer.py' 0 10099 12 "Small Room Sub" "Motion: All" "[]" "/var/cache/zoneminder/events/12/2020-08-30/10099"]
I don't know what your script are doing, but summary:Code: Select all
example.py looks like this fyi:
import sys
import pyzm.ZMLog as zmlog
import http.client, urllib
import json
# Arguments:
# All scripts invoked with the xxx_userscript tags
# get the following args passed
# ARG1: Hook result - 0 if object was detected, 1 if not.
# Always check this FIRST as the json/text string
# will be empty if this is 1
# ARG2: Event ID
# ARG3: Monitor ID
# ARG4: Monitor Name
# ARG5: object detection string
# ARG6: object detection JSON string
# ARG7: event path (if hook_pass_image_path is yes)
zmlog.init(name='zmeventnotification_userscript_example')
zmlog.Info ("This is a dummy script. Only for your testing. I got {} as arguments".format(sys.argv[1:]))
08/30/20 17:12:04 zmeventnotification_userscript_example[6066] INF example.py:25 [This is a dummy script. Only for your testing. I got ['0', '1', '2', '3', '4', '5', '6', '7'] as arguments]
08/30/20 17:13:56 zmeventnotification_userscript_example[6160] INF example.py:24 [This is a dummy script. Only for your testing. I got ['0', '1', '2', '3', '4', '5', '6', '7'] as arguments]
There could be several things.
1. I noticed your script doesn't have "#!/usr/bin/python" or wherever python is located at the top
2. When running in daemon mode, make sure your script has permissions of www-data.
3. When you executed it manually, what was the exact command you used?
4. Make sure your script has execute permissions
the ES will call the script. The rest is upto your script and how it behaves.
ES docs
zmNinja docs
ES docs
zmNinja docs
Hi
I can not get what is going wrong, so need some help.
The server runs fine when manually executed, but fails when run in daemon mode.
Using (yes, the user is http) everything runs fine, I even get zmNinja notifications. I tryed to follow the solution provided and did , but nothing changes.
So tryed also to check the value of wait in objectconfig.ini , but it was already set to 5 (and, anyway, I do not think that the problem relies there, as it works, when running server manually. Am I wrong?).
Activating debug lead me to see that is something that is not working, because
shows me that files are not updated when an event occurs, but I do not understand what.
This, instead, is the output of when an event occurs.
Using
sudo -u http /usr/bin/zmeventnotification.pl --debug
chown -R http:http /var/lib/zmeventnotification/push
tail -F /var/log/zoneminder/zmesdetect*.log
tail -f /var/log/zoneminder/zmeventnotification.log
5/12/2020 11:55:32.462774 zmeventnotification[617].DBG [main:964] [PARENT: checkEvents() new events found=1]
05/12/2020 11:55:32.462796 zmeventnotification[617].DBG [main:964] [PARENT: There are 1 new Events to process]
05/12/2020 11:55:32.463656 zmeventnotification[617].DBG [main:964] [PARENT: ---------->Tick END<--------------]
05/12/2020 11:55:32.466944 zmeventnotification[1351].DBG [main:964] [PARENT: Forked process:1351 to handle alarm eid:21055]
05/12/2020 11:55:32.467343 zmeventnotification[1351].DBG [ZoneMinder::Object:115] [Loading ZoneMinder::Event from Events WHERE Id = 21055]
05/12/2020 11:55:32.468685 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 Adding event path:/var/lib/zoneminder/events/2/2020-12-05/21055 to hook for image storage]
05/12/2020 11:55:32.468723 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 Invoking hook on event start:'/var/lib/zmeventnotification/bin/zm_event_start.sh' 21055 2 "Interno-1" "Motion Ingresso-1" "/var/lib/zoneminder/events/2/2020-12-05/21055"]
05/12/2020 11:55:32.626111 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 parse of hook: and []]
05/12/2020 11:55:32.626179 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 hook start returned with text: json:[] exit:1]
05/12/2020 11:55:32.626268 zmeventnotification[1351].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178562048 for 2]
05/12/2020 11:55:32.626413 zmeventnotification[1351].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 2: 1]
05/12/2020 11:55:34.627035 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 rules: Checking rules for alarm caused by eid:21055, monitor:2, at: Sat Dec 5 11:55:34 2020 with cause:Motion Ingresso-1]
05/12/2020 11:55:34.627141 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 rules: No rules found for Monitor, allowing:2]
05/12/2020 11:55:34.627250 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 Matching alarm to connection rules...]
05/12/2020 11:55:34.627399 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 Checking alarm conditions for token ending in:...stRS-Lnn6v]
05/12/2020 11:55:34.627598 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 Monitor 2 event: should send out as 39.5858800411224 is >= interval of 0]
05/12/2020 11:55:34.627661 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 shouldSendEventToConn returned true, so calling sendEvent]
05/12/2020 11:55:34.628256 zmeventnotification[1351].DBG [main:964] [|----> FORK:Interno-1 (2), eid:21055 isAllowedChannel: got type:event_start resCode:1]
05/12/2020 11:55:34.628777 zmeventnotification[1351].INF [main:976] [|----> FORK:Interno-1 (2), eid:21055 Not sending over FCM as notify filters are on_success:all and on_fail:none]
05/12/2020 11:55:34.966403 zmeventnotification[1351].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178562048 for 2]
05/12/2020 11:55:34.966646 zmeventnotification[1351].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 2: 1]
05/12/2020 11:55:36.966829 zmeventnotification[1351].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178562048 for 2]
05/12/2020 11:55:36.966917 zmeventnotification[1351].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 2: 1]
05/12/2020 11:55:37.239375 zmeventnotification[617].DBG [main:964] [PARENT: ---------->Tick START<--------------]
05/12/2020 11:55:37.239728 zmeventnotification[617].DBG [main:964] [PARENT: After tick: TOTAL: 1, ES_CONTROL: 0, FCM+WEB: 0, FCM: 1, WEB: 0, MQTT:0, invalid WEB: 0, PENDING: 0]
05/12/2020 11:55:37.241008 zmeventnotification[617].DBG [main:964] [PARENT: RAW TEXT-->timestamp--TYPE--1607165491.91697--SPLIT--2--SPLIT--1607165734.62769]
05/12/2020 11:55:37.241245 zmeventnotification[617].DBG [main:964] [PARENT: Job: Update last sent timestamp of monitor:2 to 1607165734.62769 for id:1607165491.91697]
05/12/2020 11:55:37.241451 zmeventnotification[617].DBG [main:964] [PARENT: There are 1 active child forks...]
05/12/2020 11:55:37.241693 zmeventnotification[617].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178562048 for 2]
05/12/2020 11:55:37.242032 zmeventnotification[617].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 2: 1]
05/12/2020 11:55:37.242566 zmeventnotification[617].DBG [main:964] [PARENT: We've already worked on Monitor:2, Event:21055, not doing anything more]
05/12/2020 11:55:37.242697 zmeventnotification[617].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178541568 for 7]
05/12/2020 11:55:37.242880 zmeventnotification[617].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 7: 1]
05/12/2020 11:55:37.243156 zmeventnotification[617].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178557952 for 3]
05/12/2020 11:55:37.243332 zmeventnotification[617].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 3: 1]
05/12/2020 11:55:37.243593 zmeventnotification[617].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178549760 for 5]
05/12/2020 11:55:37.243765 zmeventnotification[617].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 5: 1]
05/12/2020 11:55:37.243968 zmeventnotification[617].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178553856 for 4]
05/12/2020 11:55:37.244137 zmeventnotification[617].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 4: 1]
05/12/2020 11:55:37.244369 zmeventnotification[617].DBG [ZoneMinder::Memory::Mapped:84] [zmMemAttach already attached at 139910178545664 for 6]
05/12/2020 11:55:37.244533 zmeventnotification[617].DBG [ZoneMinder::Memory:300] [Shared data appears valid for monitor 6: 1]
05/12/2020 11:55:37.244761 zmeventnotification[617].DBG [main:964] [PARENT: checkEvents() new events found=0]
Try this
And see what the error is.
sudo -u http '/var/lib/zmeventnotification/bin/zm_event_start.sh' 21055 2 "Interno-1" "Motion Ingresso-1" "/var/lib/zoneminder/events/2/2020-12-05/21055"
ES docs
zmNinja docs
ES docs
zmNinja docs
[a] detected:truck:39% --SPLIT--[{"type": "object", "label": "truck", "box": [802, 539, 1006, 675], "confidence": "38.84%"}]
Any other hint for me to find where is the problem? Something more that I can check?
Added some "echo" in zm_event_start.sh to understand what was going wrong and found that, when zm_detect.py was run from the daemon, it gave the "no module cv2" error.
As a quick fix I added at top of zm_event_start.sh and now it works.
I think did not install openCV properly.
export PYTHONPATH=$PYTHONPATH:/usr/local/lib/python3.9/site-packages/
That should have been logged in zmesdetect logs. Were they not?
Where did you add the echo exactly?
ES docs
zmNinja docs
ES docs
zmNinja docs
The steps that lead me to my problems were the following:
- I compiled and installed openCV
- I found that import cv2 did not work
- I added cv2 to PYTHONPATH adding PYTHONPATH=$PYTHONPATH:/usr/local/lib/python3.9/site-packages/ to /etc/environment
Then executing zm_detect.py and zmeventnotification.pl worked fine.
So, as far as I can understand, the problem is that the variables stored in /etc/environment are not seen by daemons... (ergo, I did not install openCV properly).
No. /var/log/zoneminder/zmesdetect*.log were not updated at all, when running in daemon mode.
I added more then one, to log some informations (for example, the output of whoami, the hour in which the script is runned, and the values of the various variables). The one that made me understand the problem was this:
DETECTION_SCRIPT=(/var/lib/zmeventnotification/bin/zm_detect.py --monitorid $2 --eventid $1 --config "${CONFIG_FILE}" --eventpath "${EVENT_PATH}" --reason "${REASON}" )
DS_OUTPUT=$("${DETECTION_SCRIPT[@]}" 2>&1)
echo "$DS_OUTPUT" >> $LOGFILE
RESULTS=$("${DETECTION_SCRIPT[@]}" | grep "detected:")
